The following is for most models of the Aerus Electrolux UR models.
Lay the vacuum on it's front so you can see the bottom of the powerhead as shown below. Befrore going further, hold your hand straight and move your hand across the opening for the brush. If the bristles don't make good contact, the brush also needs replaced.
Remove the four screws. Using a flathead screwdriver, place it into the two rectangle openings (shown with red arrows) near the wheels and gently pry on tab to release the top of the power head.
Flip machine over and gently lift back of cover which will release the front. Lift off and set aside.
This is what you should see. Remove the two screws at the ends of the brush. Check carefully how the ends of the brush fit in. Gently lift out brush. This is a good time to clean entire interior of the power head. Install new belt over motor shaft and teeth of brush: set brush into place. Insert screws. Check tension of the belt.
Replace cover of power head, being sure to settle front in just beneath the lip of the front of the base first. Press down until it "clicks" into place. Turn machine over and insert and tighten screws.
