Question about GE Spacemaker 1.7 Cu. Ft. Over-the-Range Microwave
<!-- from fixya rte -->What does it mean when f3 lights up - GE Spacemaker 1.7 Cu. Ft. Over-the-Range Microwave
    Novelist:
  • 150 Answers
F3 usually means you have a shorted touch panel soft key. If you are aboe to clear the error by hitting cancell, you may be able to duplicate the issue by holding one of the keys on the panel till the error returns helping you to verify you need a touch panel. PleazerAppliance...
Posted on Nov 03, 2014
What does F3 mean?
F3 means error my friend...
Mar 07, 2015 | Microwave Ovens
Have a GE Spacemaker (Model # JVM1650SH05). Microwave works for a few minutes then displays "F3" code. How can you tell if the Touchpad or Control Board is bad? When it is working for those few minutes,...
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
Part number WB07X10959 this part can run over 100 bucks. If you shop around you could get a good price.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 28, 2013 | Microwave Ovens
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    It has an f3 code on it what ledoes it mean
    F3 means fault code number 3, I think this is Power Supply, or Magnetron.
    Feb 09, 2010 | Samsung MW1030WA Microwave Oven
    F3 Error Message
    the code means this.
    F3 Shorted touch pad panel
    Good Luck
    Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    I have a GE microwave. The display panel says F3 and the microwave beeps and will not run. If I unplug it it will then work if you use it right away. But then it will display F3 again and beep and not work...
    F3 means that your keypad is shorting.
    If you'd like to have us fix it for you, we do that for $39.95 plus parts. We repair them for customers nationwide.
    Or if you want to do it yourself, please contact me directly and I'll give you details on parts and procedure.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    William E. Miller, AS-EET
    [email protected]
    http://www.microwavedisplay.com
    Apr 26, 2008 | Microwave Ovens
    F3 Error Message
    It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
    Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
    Microwave f3 problem
    WHAT DO YOU MEAN BY (F3 PROBLEM)? MORE INFO PLEASE.
    Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    GE Spacemaker 1.7 Cu. Ft. Over-the-Range Microwave Logo
    70 people viewed this question
    Top GE Microwave Ovens Experts
    Poppa Maddo
    Poppa Maddo
    William Miller
    William Miller
    Jimmy
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
