Microsoft Xbox 360 Wireless Controller Logo
Question about Microsoft Xbox 360 Wireless Controller
Wireless remote keeps turning off
Keeps turning off by itself while playing even with new batteries
Posted by robert hodson on
Austin Ludlow
    New Friend:
    Problem Solver:
  • 13 Answers
Check the coils on both the battery pack and controller for any battery corrosion (white powdery paste) if you see any corrosion on the pack, buy a new pack, if you find some on the controller, you can try to scrape it off but it might be time to buy a new controller.
if no corrosion is sighted at all you can get into the controller with a special tool, there you can make sure everything is connected in the right place, look on youtube for a video on how it should look.
Posted on Nov 07, 2014
1 Related Answer
Anonymous
  • 5 Answers
SOURCE: my xbox 360 keeps turning itself on after i've
just unplug it when ur done
Posted on Nov 09, 2011
My Duraflame heater keeps coming on by itself
try to remove the battery of the remote, also try to replace the battery with new
My thermostat resets itself
BE absolutely sure the batteries are good. This is what usually causes this symptom, even it the 'battery indicator' isn't asking for a new battery. It happens a lot on systems that are being turned off with the breaker, safety or service switch; DON'T do that. When you put a set of brand new alkaline or lithium batteries, with the thermostat off the wall, leave NO batteries in it for about an hour. Be sure that the power is on 24/7 to the system. To stop the system from running, always use the "Heat--Off--Cool" switch.
1helpful
Tv keeps turning on an off on its own
This is a shot in the dark... but maybe your remote on/off button is stuck. remote broke/batteries low. Any new wireless devices in the room? If none of the above I would guess that the power button or the remote signal reciever on the TV itself is shorting out. I hope this helps.
Wii remotes keep turning off while playing
Try new batteries in the wii remotes that are turning off. If you still have the problem with the Wii remotes turning off after replacing the old batteries with new ones then call nintendo cause you'll have a controller problem then.
1helpful
2answers
Expensive Monte Carlo ceiling fan turns on & off by itself
needs an electrican to inspect
faulty on /off switch
flat batteries/ faulty remote
or
rodents in the roof chewed wiring
1helpful
Channel keeps changing to 'Input 2' even when playing DVD
Have you taken the remote control out of the room? Try changing inputs from the TV.
Stuck on channel 2, "No Signal" and snow
Two things may be at play here. The tv might be only programmed for reception on channel 2 and will need to be re programmed to receive other channels.
Also try some basic troubleshooting on the remotes. Start with the remote that came with the tv. Replace the batteries try the "MENU" button. If you can get into the menu try to "autoprogram" the TV
Top Microsoft Video Game Consoles & Games Experts
David Shaub
Narseman
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
