The photos during the day is whitened and very bright, and in the night is so dark, i think that there is a proplem with the Aperture which is stuck and getting much light in the day, and getting less light in the night.
It doesn't sound like the aperture to me.That would either make it too light or too dark,but I've never heard of it doing both.Double check your settings. I've had problems when I changed a setting,then forgot to reset it back. Also the cameras with a small sensor usually have a small range of f stops,so it shouldn't cause that much of a problem.It could also be the shutter.
SOURCE: Can't delete photos from the memory card
just format the card in the computer, find someone with a card reader and format it there, after format on the camera.... and hoppefully the problem will be solved
SOURCE: The photos aren't downloading from
Make sure you have the Mac driver for your camera. Install the Mac driver that came with the CD. Try to use a different USB cable. You can also try to isolate the problem by plugging your camera to a Windows OS computer like windows xp and vista.
SOURCE: Panasonic Lumix dropped
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Testimonial: "Thanks so much on the advice on the dropped Panasonic Lumix camera! I went straight to number 7 and twisted the zoom, worked wonders!! thanks a lot!:)"
SOURCE: stuck lens on on lumix dmc-LX2
u could go to best buy but it might be cheaper to buy a new camera
SOURCE: Panasonic Lumix DMC FZ30 - LCD white screen.
Firstly, use the following information at your own risk, I am simply providing my own findings for informational purposes. It may or may not be the solution to your problem. If you want a professional opinion, go to a camera repair specialist...
I have had the exact same problem. The screen on my Panasonic DMC-FZ30 started to go white with lines through it in certain positions, and then in all positions. Finally it went black.
I took my camera apart to try and find the source of the issue with my screen (by the way if you want to take your dmc-fz30 apart, there is a fantastic service manual download for free at: http://www.nemodus.info/fz30/docs/DMC-FZ30_DSC0508016CE_v1.pdf or if that does not work try http://elektrotanya.com/panasonic_dmc-fz30.pdf/download.html ).
I believe the issue stems from the contacts of the rotating screen. I would hazard a guess that somewhere along the flexi-cable there is some wear which has caused this to occur...
I have not yet solved the problem, however I do have two potential solutions.
1. I found a site where you can buy a replacement flexi-cable for the camera. The site is (http://g-plushk.com/product_info.php?cPath=53_56&products_id=653). The cable costs approx $12 (not sure which currency, it doesn't say).
The issue with this solution, after taking apart my camera, I could find no way to remove the cable completely from the swivel joint at the base of the screen. So you would probably have to buy the part and take it to a professional. (probably check first whether it is even possible to replace, I assume it is, as they sell the part...just my guess).
2. The second solution (easier in my opinion, but a bit more expensive I'm guessing). You can buy a replacement screen for the camera. Contact Panasonic for your closest spare parts distributor. I do not know the price for a replacement screen, but I would estimate that it is between $30 to $50 AUD. I would then install the part myself as it is fairly easy if you follow the service manual. However if you would prefer not to do it yourself, I would seek the help of a camera specialist to replace it...
By the way, just to put a repair in perspective. You can PROBABLY (not definitely) buy a second hand 'Panasonic Lumix DMC-FZ30' for somewhere between $80 to $120 AUD...
Hope that helps
