Question about Home Fencing
<!-- from fixya rte -->Reprogram dureslide compact 500 gate motor - Home Fencing
Posted by sharon schutte on
The manual override on my ET 500 does not work. Problem is I have no idea on what principle it works so I cannot even think about fixing it
Disengage motor from gate by using key to unlock latch and pull release latch back to disengage motor gear . Then side gate back
Oct 04, 2017 | Cars & Trucks
I have an ET 500 gate motor. My neighbour's remote opens my gate as well when she opens her garage door. How can I change my ET receiver to prevent the neighbour opening my ET gate motor?
Most garage door openers and I assume gate actuators have jumpers or settings if computerized to change frequencies.
Both the remote and unit will have to be changed.
Larry
Aug 05, 2016 | Building Materials
How do I dry out an electric gate opener that got wet?
what is the make and model of your gate motor or central unit it might have to be reprogrammed after you dry it with a hair dryer without the battery in it
Nov 12, 2014 | Home Fencing
Super 500 g8z gate motor Manual
How do u connect a new remote control to the super 500 g8z gate motor?
Oct 23, 2013 | Home Fencing
I got my centurion gate motor D3. the problem is when i press the remote an LED lights but the gate does not open, i opened the motor cover and there is no light nor sound from the motor. the gate can be...
Try to reprogram your remotes.... or replace the batteries even if the l.e.d. still works (it only takes half a volt to make the l.e.d. work but almost the full charge of the batteries are needed to send a working signal.
Oct 18, 2013 | Televison & Video
Program remote for DACE Compact 500 gate motor
how do i set up a new remote for the compact gate motor
Tsvm
Charlie
Aug 17, 2012 | Locks & Locksmithing
Mighty Mule 500 motor repair
Try Mouser.com part # P6KE16CA 36 cents a piece.
Jan 12, 2012 | GTO Mighty Mule Automatic Gate Opener For...
Home Fencing Logo
739 people viewed this question
Top Home Fencing Experts
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
