Question about Hype 2.4GHz Wireless Optical Mouse -Blue
Hype optical mouse model no. HY-7005-WMA 2.4GHz isn't working properly, wont connect to any device. How do I get the adapter signal to read on my laptop?
Added two triple a batteries so the light comes on but the mouse isn't responding to the adapter signal or the adapter isn't connecting to the computer, either way I can't use the thing and I would like to so how in the world do i fix it?
Posted by Victoria Lopez on
  • Harrie Oct 31, 2014
    Hi Victoria Lopez, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what computer? what OS? not only the grand, but also the version please.
  • Kitzia PVM
    Kitzia PVM Feb 20, 2017
    hi, I have the same problem as Victoria, the computer is a lenovo with Windows 10, the mouse was working perfectly well until the day i left the laptop to hybernate, then the mouse stopped responding
leo3lex
    Habit-Forming:
    Scholar:
  • 69 Answers
I don't know your particular mouse, but there is a chance it might not be plug-and-play, meaning you have to use a disk or download software/drivers to make it work. If you installed software using a disk, check compatibility with your operative system and look on internet, on manufacturer's support page, for up to date drivers.
Posted on Feb 20, 2017
Frank Zlotkowski
    New Friend:
So you're saying you've tried connecting to other devices to no avail?
Might be worth reading the direction carefully. Sometimes there's a reset/rescan button(small) on the mouse that needs to be engaged after everything is plugged in.
Posted on Nov 13, 2014
DOES HYPE OPTICAL MOUSE MODEL NO. HY-7005-WMA 2.4 GHz have a usb receiver? how do I connect
if this is a wireless mouse (WI-FI) then you will need the accompanying usb receiver to make it work
Feb 01, 2015 | Optical Mouse Computers & Internet
Hype HY-7005-WMA works but I can't assign the buttons, there is no driver for that
The Hype HY-7005-WMA mouse is a very poorly supported product and the buttons on the mouse are preset to only work as set functions and cannot be changed. If the buttons on the mouse do not respond in any way, they may be broken due to poor product quality and you should seek and exchange or return from where you purchased the product from.
Jul 19, 2014 | Hype 2.4GHz Wireless Optical Mouse -Blue
Hype HY-7005-WMA mouse, how to connect
hi,
there should be a little dongle included with the mouse, you attach that to the computer and turn on the mouse and it should connect automatically, or you might have to press and hold the connect button for the dongle and the mouse to connect
but first - connect the dongle to the computer and see what happens
I attached a photo - look for the little piece AKA dongle
Oct 19, 2013 | Computers & Internet
Laser mouse very inaccurate?
Instructions
    • 1
      Check your wireless connection. If you are using a wireless adapter or USB linking device, ensure that everything is plugged in properly. The best way to do this is to unplug the device and then plug it back in, making sure everything fits snugly.
    • 2
      Try to re-sync your mouse with your computer/adapter. If your computer came with wireless networking capabilities (such as Bluetooth) and your mouse uses this signal to communicate with the computer, go to your computer's control panel and turn off the network for a few minutes. Then reboot the network and see if the connection to your mouse has been restored. If you are using a wireless adapter, go to the wireless utility that your computer uses to manage the wireless mouse (this can usually be found in the "programs" section) and repeat the above process.
      Look at the bottom of the mouse. If your wireless mouse has a trackball, try removing the cover and cleaning the individual wheels on the inside of the mouse with a Q-tip. If you are using an optical mouse, then try cleaning the bottom of the lens with a soft tissue and a frugal amount of glass cleaner.
    • 4
      Ensure that any drivers needed for the mouse are still installed. Although it is unlikely, the drivers that facilitate communication between your mouse and computer may have been accidentally corrupted or erased. Try visiting the mouse manufacturer's website to download new drivers.
God bless you
May 24, 2013 | HP Wireless Optical Mouse
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
Why does the green light keep blinking on my T0185
what OS? XP? why post at all lacking such a key fact?
click start, controlpanel, click system , bingo what OS you have.
is the PC web connected , it must be for PnP to work.
this kbd is 12 years old at least, (see posts at dell that old)
are you trying to use 12year old hardware on windows 10?
vast things do not work on w10 now, like most things over 10 years old. vast things, usb things, wireless usb things. endless list.
that is because there are now w10 drivers for those things now.
google find near nothing on
T0185, it is so old. did you look in device manager?
then see keyboard devices.
then right click (be web connected) and pick update driver. first?
at dell forum , i see 12 years of folks asking for drivers on this
and not one answered with 6000 views, not a good sign that.
RIP dell wireless kbd. no manual either found. dell , has ghosted this
Oct 01, 2017 | Dell (H2993) (T0185) Keyboard and Mouse
The keyboard is not working. Nothing comes out
I don't know your level of technical experience, so some of these may seem obvious. These may not be in the best order, I've added them as I thought of them.
1) check the batteries in the keyboard and mouse. They can go through batteries in a big hurry sometimes. If just changed double check polarity.
2) check the connection(s) for the receiver. If you have pets check for chewed wires.
3) have you added any new USB devices. They may be using to much power from your USB ports
4) have you added any other wireless devices, includes non-computer devices.
5) have you tried resetting the keyboard and receiver signal.
6) check USB power output. You can plug in a different USB device and see if it works.
7) does your receiver require batteries (very rare).
8) you may need to reinstall your keyboard drivers and software.
Most wireless keyboards operate in the 400 Mhz range so do most wireless networks and many phones, these can all interfer with your signal.
Jun 30, 2010 | Microsoft Wireless Optical Desktop 1000...
Changed battery correctly but the on/off green light keeps blinki
you have to hit the button on the wireless base adapter as well as the one on the mouse its self
good luck and pls rate this post
Mar 23, 2010 | Logitech Wireless Access Duo Optical...
I bought product and wont work
There are couple of reasons for your wireless mouse not to work. Please try changing the batteries first. Make sure that there are no other devices that might interfere with the signal. If the mouse is bluetooth then you might have to re-pair the device with the laptop in order to get better connectivity. On the mouse that you have is there was a "Connect" button that you need to press to get a new signal from the transmitter. Just to let you know, the transmitter is working with infrared; it only goes up to about 20 feet when in-line before it starts losing its signal.
Let us know if you are looking for something more else accept the suggestion.
Thank You for contacting Fixya.com
Mar 07, 2010 | GE Wireless Optical Mouse
Hype 2.4GHz Wireless Optical Mouse -Blue Logo
Top Hype Computers & Internet Experts
k24674
Are you a Hype Computer and Internet Expert? Answer questions, earn points and help others
