Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
Posted on Jul 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with lenses
I have canon powershot sd750 an dwhen i turn the lenses dosent open complitly and i`m freak out
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on Aug 19, 2012
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10441521
Points
622693
Try the procedures in this tip.
5 Related Answers
Anonymous
  • 734 Answers
  • Posted on Dec 04, 2008
SOURCE: Canon powershot SD750 will not turn on.
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
dnewcombe1
Dana Newcombe
  • 1564 Answers
  • Posted on Sep 29, 2009
SOURCE: canon powershot a620 shutter won't open
You need to clean the contacts inside the battery compartment. Do this with a Q-Tip swab dampened in rubbing alcohol. It would be good to clean the battery and the charger also. Thank you,Dana
Anonymous
  • 3 Answers
  • Posted on Dec 23, 2009
SOURCE: Canon PowerShot SD870 IS camera - Lens Does Not Fully Retract
Canon SD870 IS. Lense Error. Would not retract on power-down. Lense error reported when retracting zoom.
Noticed the rectangular frame about the lens was rotated off center. Manually rotated (squared-up) the lens rectangle while repeatedly powering the camera on and off. Modulating the power allowed for easier rotation of the rectangular lens frame.
Once the lens frame was square with the body of the camera, the lens completely retracted on power-down, and also zoomed in/out without error.
Anonymous
  • 11967 Answers
  • Posted on Jan 26, 2010
SOURCE: canon sd750 powershot lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Anonymous
  • Posted on Feb 12, 2010
SOURCE: how do i turn on the date stamp on my Canon Powershot SD750
Move top selector all the way to right,
1.put in auto mode
2. Hit Function set button
3. Where it lets use choose sizefrom L, M1, M2...scroll to Post Card 1600x 1200
4. hit function set again
5. Hit Menu, now you can select time date stamp
6. took me awhile to figure it out
Lense error, restart camera problem
If it's "lens error", then check your lens for damage or being jammed.
If it's "lense error", then I don't know what a lense is.
I am having a problem with my sd750. When I turn it on, it runs fins but the lens only opens half way. I can cycle it on and off and it doesn't work properly. It seems something with the zoom lens...
Dear sir,
this happens when the clearance for the lense mechanism to open and close is being insufficient due to -small bits of sand or lint that may become get trapped in the mechanism which is commom while taking photos in open dust spaces.
It is advised to take the camera to a camera repair shop and have it disassembled and cleaned,if delayed the problem gets complicated....
thank you..take care....
2helpful
2answers
I have a Canon PowerShot SD750. I dropped it and
If this is the case, the camera might have internal damage. Might be better to send it back to Canon delears/shop for repair. Please try below link
Canon
2answers
Need to remove lense on Powershot 870 to clean dust out
I wouldn't advise that you do it yourself unless you did your homework and know how to take it apart. I would buy a air can dust blower and try to get rid of it like that, followed by a lens brush to clear away extra dabre.
If nothing works, take it in for a service by your local camera store or into Canon.
1helpful
My sd750 will not start up
Does the lens cover move when you do this? If it doesn't, it sounds like that might be the problem.
2answers
Connect the USB cable and turn on the camera, open My Computer, you will see an camera icon 'Canon xxxxxx'. double click this icon, all pictures will show up, select the pictures then drag them to your folder. Just like you copy files from this folder to another folder:-)
5helpful
3answers
Canon ixus 75 digital camera reset?
The manual states that the battery door was opened during use. Close the battery door and turn it on and off. You may need to push it closed to make sure the battery connections are made.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
