Reddy Heater-30-55,000 BTU Variable Logo
a
alanphillips Posted on Oct 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a photo sensor for a 55,000 btu kerosene heater. model# R55CT/ B55CT
Where is one available?
Marc Powers
Level 2:
Scholar:
  • Expert 146 Answers
  • Posted on Nov 10, 2014
Marc Powers
Expert
Level 2:
Scholar:
Answers
146
Questions
0
Helped
82870
Points
284
You can find the item at www.desa-parts.com for your R55CT or B55CT Reddy Heater.
Here is a link to that item.
https://www.desa-parts.com/product/PHOTOCELL-AND-BUSHING-FITS-DESA--MASTER-/PP236
5 Related Answers
Anonymous
  • 625 Answers
  • Posted on Dec 06, 2007
SOURCE: Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
A
Anonymous
  • Posted on Feb 17, 2008
SOURCE: r60 reddy heater 55,000 btu
Reddy Heater 50,000 BTU Portable Forced Air... I will not buy onother Reddy Heater. they are garbage even if they were giving them away. I wouldn't want it.
steve_lima
steve
  • 181 Answers
  • Posted on Feb 25, 2009
SOURCE: kerosene heater won't stay lit
check to see if the photo cell is clean.to check it open the side compartment and look for the blue and white wire comming from photo cell,on the reset switch there is a white wire and a blue wire.hook these two wires to gether at the switch and try to refire the unit.if the unit keeps running the photo cell is bad and NEEDS to be changed.if the unit shuts off the safety switch is bad.
Anonymous
  • 1476 Answers
  • Posted on Feb 14, 2010
SOURCE: I have a Reddy Pro 115 BTU kerosene heater the fan
When you say that the fan starts then stops I assume you also mean that the burner starts and stops. If this is correct and the unit is more than a couple of years old you probably need to change the filter in the back and set the pump pressure. Both the filters and the gauges to set the pressure can be found at www.reddyheat.com along with a good explanation as to why you need the gauges. The pressure is set by bleed air pressure and must be exactly 3.5 psig. The gauge is the only accurate way to do it. The filters clog and change the pressure. When the difference is enough the unit will not run. Now with that said there are several other things which you should check. Check the fuel tank for water. Remove any you find. Remove the cover on the right side as you look at the unit from the front and remove the circuit board. Check for cracked connections. If you find any resolder them and reattach the board. That should take care of the unit and get you back to making heat. Let me know if you need anything else.
hardrocko
Thanks for using FixYa
Anonymous
  • 224 Answers
  • Posted on Dec 23, 2010
SOURCE: I have a 55,000 BTU
Water in the fuel tank, I personally had this problem this morning irritating but was simple to cure. Empty your fuel in to a clean five gallon bucket and observe, fuel is lighter than water and will float on top water settles to the bottom. You now have to dry out the tank, get creative I stuffed mine with rags and sopped it all up, this worked fine for me. You can siphon off the fuel from the water and re-use the fuel. Just be careful not to siphon off the water with it.
Reddy Heater kerosene 110,000 btu . plup it in, fan runs, blows smoke out the front, leaks kerosene also from front, i have cleaned photo cell, replaced plug, cleaned filter and checked lines for cracks,...
Just because there is fuel & spark does not necessarily mean there will be combustion. The fuel must be delivered at the correct pressure, the correct volume, and must be delivered as a fog- not a mist.
My suggestions:
  1. set the pump pressure
  2. be sure the fuel filter is clean
  3. be sure no air leaks or vacuum leaks
  4. Desa recommended annual replacement of the nozzle. They wear out. When was the last time yours was changed?
More troubleshooting tips
My reddy heater isnt getting kerosene to the nozzle can anyone help?
From what you have said, it sounds like the nozzle is clogged . If you will send me the Model Number of your heater, I'll sent you a copy of the Owners Manual/Troubleshoot Guide, if you have misplaced yours.
I have a reddy 55,000 btu kerosene heater i bought used and it worked fine the first day it stayed on as long as i wanted it to now it only runs for like a minute and i don't know why it has plent of...
It could be a pressure problem, old fuel, clogged nozzle, etc. If you can furnish me with the correct model number, I will be able to help you further. Reply by using the Leave a Comment link.
Thanks
Runs than shuts off after a few seconds
Is this a propane or kerosene heater? If it is kerosene, check your fuel, clean your tank and start with fresh fuel. Check your fuel filter/air filters at the back of air pump. Make sure your ignition system is working.
2helpful
I have a 55,000 BTU Kerosene heater that will not fire up. The fan, ignitor are all working. What could cause this?
The fuel is drawn from the tank by vacuum. If there is any kind of dirt in the fuel or tank, it will clog up that tube and not fire up. Also there is a foam filter at the rear that could be dirty. There is also a reset button by the filter that needs to be reset every time it runs out of fuel.
I have a portable forced air heater Model R55A heater size 55,000/Hr can I use diesel fuel instead of kerosene?
You can, but prolonged use of diesel fuel will burn out the cone faster. Too hot. And it stinks alot worse than kerosene.
Diesel
you can run a premium diesel but it does tend to burn dirtyer than K1 kerosene.
Unit will start, run about 5 seconds and
You did not state the model numbers of the heaters, so a good guess is all that I can do. Manuals might be available, but models are a must.
By your description the heaters are Hot Surface Ignitor types, opposed to the older technology spark plug heater. Right or wrong? Technology is different & troubleshooting is different.
The heaters are shutting down because the photocell is not seeing the flame, or the flame color is not absolutely correct. The photocell tells the computer to shut the heater down for safety reasons. It's going to be your job to troubleshoot and find out what's wrong.
READ these tips
Top Reddy Heating & Cooling Experts
Paul Carew
vince
NOEL
NOEL
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
