Paper jam error - no paper in printer - switched off - disconnected - removed all paper - removed and replaced print cartridges - still jam error - no paper what so ever in printer
SOURCE: Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
SOURCE: Continual paper jams in rear of printer
If the paper is jamming at the exit rollers, you will be need to clean the rubber on the rollers. It gets shiny and does not grip the paper to take it away.
SOURCE: HP psc 1310 - gave paper jam and print cartridge
clean the rubber rollers of the printer and try to print. if it is still having the same problem. reset the printer by unplugging the power cord of the printer while its turn on. then plug the power cord back in. once the printer is on press and hold the power/on button and the size button. when the on button is flashing then release the buttons and try to print again
SOURCE: Continual Paper jam HP Officejet 6310
There's a couple things that can cause recurring paper jams. Most often, all the pieces of the jammed paper aren't removed. This video shows you where to look to find all the jammed paper. It also offers some other solutions as well. If the solutions in this video don't work, the printer is likely broken.
