Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Sony big screen tv not playing picture after 5 minutes or so
Tv plays for awhile, then statrts to fade to a all blue screen.
Posted by shabazz on
  • NELLY2183 Dec 11, 2007
    I'M HAVING THE SAME PROBLEM MY TV STANDBY LIGHT KEEPS BLINKING AND WHEN I TURN ON THE T V IT TURNS BLUE AND THEN SHUT OFF
Cary Farah
    President:
  • 4,402 Answers
You have a bad picture tube, or perhaps a picture tube drive problem.. To see what is bad, remove the front speaker grill under the screen in the front. Remove the screws that hold on the board that covers the front. Insidfe this set, WITH THE TV SET UNPLUGGED< Locate which one of the tubes is the blue one. Gently pull off the board from the end of the picture tube and swap it with the green tube right next to it. The green tube is always the middle tube. If the blue comes up again, then the blue tube is bad and you will most likely be better off to buy a new TV set. If the green comes up as the bright one, swap back the boards, call a tech and tell them there is a CRT driver board , or an RGB drive problem. This should not cost you an arm and a leg to get repaired. Good Luck, and let us know how you make out with the repair of this TV set.
Posted on Dec 19, 2007
After turning on my sony kdf-55wf655 tv for 3-4 minutes it automatically fades out to a blk screen (also no sound) and the green power light starts to blink. the tv stays in this status for appox 2-3...
The projection lamp,the sign of it life is over.The projection lamp been in the tv about 1 1/2 or 2 years,used the tv on and watches at least 4 or 5 hours a day?It time,to replace it,with a new projection lamp.
Aug 06, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Westinghouse LTV-32W1 Plays for awhile then no sound or picture
could be two thing the new ps board you put in was defective or the inverter board is failing
Dec 07, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Half the screen is blue
the lcd panel is faulty. replace it at a service centre
Oct 13, 2009 | Sony DCR-VX2000 Mini DV Digital Camcorder
Screen fades to blue.
The Blue SCREEN setting is too high. These adjustments are located inside the TV behind the front panel. There are two screws behind covers and then a wooden panel to remove to access the adjustments. The leftmost set are for BLUE, the middle are GREEN, and the right are RED. The top row are FOCUS and the bottom are SCREEN. Focus will focus/unfocus the tube and Screen will adjust the power of that tube (there are 3 tubes, one for each color). If Screen is adjusted too high, horizontal lines will appear (my TV had red lines, but I played around with the knobs and saw that it could happen on any of the colors). Additionally, if SCREEN is set even higher than that, the tube could go so high that it turns the whole screen that color (in your case, blue). If this happens the TV will shut down, probably due to either overheating or overvolting. To fix this issue, turn the appropriate SCREEN dial down until the lines go away. In your case, you want to turn the lower left dial down. Don't turn it too far down, if you turn it more than necessary the TV can give you an AKB error (noted by the STANDBY light flashing a sequence of 5 blinks).
Apr 02, 2009 | Sony KP-57WS500 57" Rear Projection...
Picture comes on then fades to blue
Check the info from this website to see if you are able to fix your TV. You should turn the blue screen control down slightly counterclockwise. If that did not work, then more likely you have a video amplifier IC defective or a blue CRT.
Dec 19, 2008 | Sony KP-57WS500 57" Rear Projection...
PS3 60GB
Contact sony @ 1-877-253-SONY(7669) for a replacement unit
Sep 04, 2008 | Sony Playstation 3 (PS3) Console
Sony big screen tv, no color
focus block or neck boards on thr picture tubes
Nov 11, 2007 | Sony KP-46WT500 46" Rear Projection...
Repair of my big sony screen tv
FADING TO BLUE SCREEN
Sounds like you have a problem with the blue gun in your picture tube or its drive circuit. You might remove the back cover and gently tap on the neck of the picture tube using a plastic screwdriver handle while watching the screen in a mirrow. If the picture flashes back on or on and off then the picture tube is the problem. If this is a projection tv you have three separate tubes : red, green & blue. you'd need to tap the blut one.Gently!!!! Stargazer
Feb 13, 2007 | Sony KP-53HS20 TV
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
125 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
