Question about Krups Food Processors
I have a Krups Master Pro Plus Food Processor that has sat unused for several years.  Tried to use it today and it won't start.  Would lack of use cause motor to die  I have a Krups Master Pro Plus Food Processor that I've never used. Tried to use it today and can't get it to turn on. It's sat unused for several years, could this cause motor to die?
Posted by sexyherwiggs on
4 Related Answers
Anonymous
SOURCE: Krups Master Pro Compact model 703 -need a part
Dear J:
I may be able to help you to find your Part but I am wonder if it is possible you can help me with a copy of the Owner's manual of the Krups 703, I lost mine and i my need some part too.
I will really appreciate if you e-mail me a copy to [email protected]
I will look for your part in local Parts shop.
We have here in Miami one which is very complete Goodsman.
Thanks,
Greg
Posted on Sep 18, 2008
kimngeo
SOURCE: I have a food processor
www.estore.fox-international.com
or 1-800-738-0245 mon-fri 8:30am-8:00pm ET
Posted on Dec 02, 2008
Anonymous
SOURCE: assembly directions for food processor
I had same problem and found answer on another website:
Front on machine is the one with the label on it.
One thing: the instructions aren't particularly clear on assembly. The bowl handle should be *toward* you when you lock it on the base, pointing toward you when you stand facing the label side with motor to right and bowl to your left. Then the lid just slides right on and when you turn counterclockwise a quarter of a turn it locks into place with no effort as the key slides into the slot and locks. I had this idea the handle should be on the backside of the machine, and it will fit on that way, but then you can't get the lid to fit securely.
Posted on May 26, 2009
SOURCE: Where can I get a replacement blade for a Krups
Which blade do you need? I am also having problems finding a replacement blade for the same machine - the only one we use is the one that grates but the centre melted recently. Can we do a swap?
Posted on Dec 15, 2011
Sir, I have Molinex Food Peo of model 370.It has started giving noise when switched on. More over its safety switch is also broken. need to replace safety switch. I feel the carbon brushes have been worn...
Sir, I have Moulinex Food Processor of model Master Chef 580 .It has Problem with the Moulinex DG6 6.34 Cups Food Processor Sir, I have Molinex Food Processor Master Chef model 580.It has started giving noise when switched on. More over it's safety switch is broken. need to replace safety switch.Also Motor's Rotor's winding is burnt.Needs rotors replacement. Please intimate service center &spare part supplying agency in India. I am in Vadodara (Gujarat) India
Jan 19, 2011 | Moulinex DG6 Food Processor
Where can I get a replacement blade for a Krups rotary 500 food processor?
Aug 30, 2010 | Krups Food Processors
Dear J:
Thanks,
Greg
Aug 11, 2008 | Krups Food Processors
Food Processors Logo
388 people viewed this question
Top Krups Food Processors Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Krups Food Processor Expert? Answer questions, earn points and help others
