For all Free appliance repair videos visit our VIDEOTUTORIALS1, If the Bosch fan motorin the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter. To gain access to the BOSCHelement you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the elementyou willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the elementis open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine. 2, If your BOSCH fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motoris working you willsee the blade turning fast if it is ok. if the element is heating but the fan motoris not blowing the heat into the oven thenyou need To replace the oven fan motoris a little moreexpensive and a bit more involved. 3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your BOSCH oven thermostat 4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timerinto AUTO mode,simply put oven back to MANUAL mode and all should be working again.
If you have aBOSCHelectric Cooker or Fan Oven which isnot heating it could be one of the following problems. 1, If thefan motor in the back of the oven is goinground and the temperature light is on (normally little red light), but there isno heat then you will probably need a new oven element, these are generallyvery easy to fit and readily available from our website these can be testedwith a electric meter. To gain access to theBOSCH elementyou will have to remove the back platefrom inside the oven. Once removed you will see the fan andelement,if you look closely at theelementyou will probably see a small holeburnt in it where it has blown. Sometimes however there is no evidence of afault but theelement is open circuitie: broken inside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If yourBOSCHfan oven is getting warm but takes avery long time to cook or is burning the food more on one side than the other,then you need to check if your ovenfan motor is working you willsee the blade turning fast if it is ok. if the element is heating but thefan motor is not blowing the heat into theoven then you need To replace the ovenfan motor is a little moreexpensive and a bit more involved. 3. If you have theopposite problem ie: your oven is over heating and burning everything then youwill need to replace yourBOSCHoventhermostat
4, A quite commonand easily overlooked answer is if yourBOSCHoven is not working at all ie: no heatand no fan then the chances are that someone has put the oventimer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to: www.bosch-spareparts.co.uk
or www.espares.co.uk/bosch
