Question about Elite Sl3000 1hp Slide Gate Motor, Receiver & 2 Remotes
MY ELITE SL 3000 UL WILL NOT WORK WITH REMOTE. IT WILL WORK WITH THE LOOP. PROBLEM WITH BATTERY OR NEED TO REPROGRAM THE REMOTE, IF SO WHERE IS THE LEARN XMITTER LOCATED PLEASE HELP
HOW TO GET THE REMOTE WORKING WITH MY SLIDING GATE
Posted by MARY on
HalmarV
    Scholar:
  • 99 Answers
Hi Mary, do you have more than one remote for the gate? Your remote needs to be paired with the gate receiver. Normally you need to push a certain button on the control panel to enable learning mode then you press the remote button you want to use. You will have to follow this learning process for your device. Please keep in mind that just any remote will not work with your gate, it needs to be on the same frequency and use the same modulation mode.
Hope this helps.
Posted on Nov 15, 2014
2 Related Answers
Justin Washburn
  • 116 Answers
SOURCE: Sliding gate will not close
Check track for obsticles, Does it slide smoothly or does it hand have way and get more difficult, Clean any sensors you can see with a clean rag. Let me know what you find.
Posted on Dec 11, 2008
janman
  • 369 Answers
SOURCE: my sl 3000 ul gate wont open unless I help it out
if the motor cant rotate the shaft by itself, its likely a burned coil in the motor, but if the motor is running but not moving the gate then its a broken gear
Posted on Jan 24, 2010
Gate will open pushing open button but cant use remote
General answers only, sorry. Look for loose or corroded connections, especially where wire nuts were used. Reprogram the remote receiver. Disconnect power to the receiver for a short time. Reconnect and reprogram. I hopes that any of this helps. I have operators to the much like witch craft, a black science!
May 10, 2016 | Elite Gate Opener Sl3000 Slide Gate...
Sliding gate wont always open
Since there are few details on the circumstances of when it won't open provided I will try to guess what is happening.
Usually this is related to the strength of the transmitter (clicker or remote) signal. If you have radio interference from ham radios, air fields or other government agency, it will affect the reception or your gate receiver. Other common issues include the distance from the operator, how long you hold down the button, and the age of the battery in the transmitter.
You might try extending the receiver antenna up higher. If this makes it worse, you may need a directional antenna like the Linear EXA 2000.
We have also found the Linear SMDRG narrow band receiver to work well when we have interference issues.
May 18, 2015 | L A Ornamental Security Electric Driveway...
What is wring.?
The programming on your remote buttons probably got overridden. Just reprogram your remote's buttons for the alarm and gate .
Mar 29, 2015 | Building Materials
How do I sync a Chamberlain remote 371LM to a Chamberlain gate opener Elite Robo Slide?
There are two possibilities. The first and easiest is a sync button on both. Much like a Wii remote, you might be able to find a sync button (most likely small and indented) to have both devices search each other out. The other possibility is registering the remote to the gate. You may have to call in and have help, including giving find and giving the remotes code.
Elisa Jed ' http://abfabrications.com.au/fences-gates
Jul 19, 2014 | Home Security
How to program a liftmaster remote to an eagle gate opener
I have a eg640 and my mother in law has the same eg640 for are gate
Aug 06, 2012 | Elite Sl 3000 Ul Sliding Gate Operator
Beninca Sliding gate
YOU NEED A TECH GUY TO SEE WHAT IS THE PROBLEM.
Dec 18, 2011 | PSB Home Security
1. I have an elite slide gate opener it will open all the way and after a few sec will close. 2. With the remote the gate will not stop and stay in the open position.
the auto close has been set or the motor has been set up in reverse and it is auto reverseing,make sure the gate is opening up all the way, if it is not just help it along and see what happens.
Apr 13, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
The photo eye sensor is defective of is out of its correct posistion!
Hope this was of help!
Dec 11, 2008 | Elite Sl 3000 Ul Sliding Gate Operator
Elite Sl3000 1hp Slide Gate Motor, Receiver & 2 Remotes Logo
372 people viewed this question
Top Elite Home Security Experts
ADMIN Canada
ADMIN Canada
ray gallant
Are you an Elite Home Security Expert? Answer questions, earn points and help others
