I have a Grohtherm wireless 36023 it is connected up to my high pressure pump and it has stopped supplying hot water...the water comes out at a high pressure but it freezing cold the white box which the pipes are connected to leaks water from the hot water pipe area...any ideas?
There are multiple possibilities:
- the power to the main control could be off (seems unlikely if you can turn the water flow on and off)
- the thermal element that heats the water could be burned out (may not be a problem if this is only a mixer unit and relies on external hot water supply)
- there could be a problem with the solenoid that opens to allow hot water to flow through the unit
- there could be either no hot water getting to the unit or blockage so that hot water will not flow through to the mixer
Start by making sure there is power. Then you may need to disconnect the hot water supply (after turning it off at the source) and then check to see that hot water will flow. If you get hot water to the unit then there is something internal keeping the hot water from mixing with the cold.
SOURCE: WATER RUNS COLD
ITsounds like you still have air in your lines try bleeding lines out some times it takes a while .or your getting air in lines some where try looking at the boiler at fittings .
SOURCE: Shower will not get hot enough
i have no experience in fixing showers however mine once did this when i remodeled my bathroom so i called one of the guys that was workin on it and he told me that he had takin something out what looked like a gasket and said it was a scald preventer and from then on my shower has been fine hope this helped
SOURCE: Danze pressure balance single handle shower faucet
it the valve is full of dirt or needs to replaced not all the time but i have fix many buy just cleaning it out or pipes are fasten down. try just cleaning.
SOURCE: no hot water
When you adjust the dial to mix the hot and cold for your desired liking, it goes into a mixing chamber before going to the shower head, im asumming your issue is within the mixing chamber.
SOURCE: hot water pipe hot going into mira shower but no
need to adjust the anti-scald [protection] new systems are shipped in cold position and u adjust it to ur comfort
