Question about HP Pavilion dv9000z Notebook
No display and bios beeps
My dv9000 stopped working one day out of warranty :(
no display, 3 system bleeps 1 long 2 short.
spoke to hp live help they say that i could always buy the extended warranty! say its the graphics adapter :( there has been no other suggestion up to this time that my graphics were going bust.
spoken to currys and consumer direct. Currys tried to avoid any liability but then agreed to replacw or foot repair pending a third party engineers report and proof of purchase.
When they received a report from the pc repair engineer saying was not repairable due to onboard graphics module and related expense, it was rejected by currys who claim it was not detailed enough. I asked them if they could not just pick it up and check it out themselves, but this would cost me £145.
So took to another computer engineer who has written a report detailing all the things currys say they want from a report:
the fault
the cause of fault
the cost of repair
recommendation for repair or replacement.
Tried to explain that this is a component failure which is the cause but Currys dont understand. The engineer has put in the report that it is a component failure which has not been caused by misuse or neglect.
any advice
Posted by sadness on
  • sadness Nov 11, 2007
    but if i take the warranty now they are not necessaily going to cover it either. from what i hear of hp tech support they are even worse than currys. Consumer laws do say that i should be able to expect a reasonable amount of wear and time from a product that i have spent 1200 pounds on depsite the length of the maunfacturers guarantee. And that Currys as the retailer are the ones responsible.
  • Nic Spiers Nov 25, 2008
    Similar beeps! Blue lights come on, beeps and hangs. 13 months old and, from "Sadness's" experiences, not a lot of point claiming on the warranty. UNLESS of course, HP have a bad batch of these laptops. In which case could we not all band together and pressure HP?
Pookeybrain
  • 51 Answers
"but Currys dont understand." - Sounds like a case of willful ignorance, but if the laptop is out of warranty they aren't going to cover it regardless of what some clerk promised you.
If I had a laptop that nice I'd opt for the extended HP warranty.
It's really your cheapest option at this point.
Posted on Nov 11, 2007
  • Pookeybrain
    Pookeybrain Nov 11, 2007
    Short of you having spilled a beer in the keyboard, HP will fix your laptop with the extended warranty in place.
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
http://www.computerhope.com/beep.htm
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
Advent Sienna 500 won`t switch on and keeps bleeping
First thing is to identify beep codes.
Aug 25, 2012 | Computers & Internet
My hp-compaq dx2300 microtower restarts automatically when working. It is installed on win xp sp3. Please let anyone help if solution is known.
Hi names Rui, i question for you does your PC give a beeping sound when you turn it on? if does can you tell me how many beeps it gives?
if it give a designated number of beeps this might be the problem i will give you a chart so you can differentiate the warning beeps you hear.
warning beeps:
1 Short Beep DRAM refresh failure
2 Short Beep Parity circuit failure
3 Short Beep Base 64k RAM failure
4 Short Beep System time failure
5 Short Beep Process failure
6 Short Beep keyboard control gate A20 failure
7 Short Beep Virtual mode exeption failure
8 Short Beep Display memory read/write test failure
9 Short Beep ROM BIOS checksum failure
10 Short Beep CMOS shutdown read/write error
11 Short Beep Cache memory error
1 long, 3 short Beep Conventional/Extended memory failure
1 long, 8 short beep Display/Retrace test failed
hope this will determine the problem if none of this warning beep is heard try reseting the power botton in you PC cause sometimes the power botton will loosen cause of continuous use of the botton.
hope this will help you.
Jul 20, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
Can not reinstall os on mt acer 246lc it bleeps 4 times and swithes off
Without knowing what motherboard is in the unit - it will be difficult to determine what the 4 beeps means.
Generally, 4 beeps means issues with :
- memory
- video card
- keyboard
- motherboard failure
Things to try -
- make sure there is no keys stuck down
- remove the battery and AC adapter, remove and re-install the memory sticks (reseating the memory)
If this does not work, your problem may be more serious. Let us know the results of the above suggestions.
Nov 17, 2009 | Acer Computers & Internet
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
4 beeps 2373 laptop
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
IBM POST Diagnostic Code Descriptions
Code Description
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Colour/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Colour/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
Code Description
1 Short Beep System OK
2 Short Beeps Parity error in the first 64 KB of memory
3 Short Beeps Memory failure in the first 64 KB
4 Short Beeps Memory failure in the first 64 KB Operational of memory
or Timer 1 on the motherboard is not functioning
5 Short Beeps The CPU on the motherboard generated an error
6 Short Beeps The keyboard controller may be bad. The BIOS cannot switch to protected mode
7 Short Beeps The CPU generated an exception interrupt
8 Short Beeps The system video adapter is either missing, or its memory is faulty
9 Short Beeps The ROM checksum value does not match the value encoded in the BIOS
10 Short Beeps The shutdown register for CMOS RAM failed
11 Short Beeps The external cache is faulty
1 Long, 3 Short Beeps Memory Problems
1 Long, 8 Short Beeps Video Card Problems
Phoenix BIOS Beep Codes
Note - Phoenix BIOS emits three sets of beeps, separated by a brief pause.
Code Description
1-1-3 CMOS read/write failure
1-1-4 ROM BIOS checksum error
1-2-1 Programmable interval timer failure
1-2-2 DMA initialisation failure
1-2-3 DMA page register read/write failure
1-3-1 RAM refresh verification failure
1-3-3 First 64k RAM chip or data line failure
1-3-4 First 64k RAM odd/even logic failure
1-4-1 Address line failure first 64k RAM
1-4-2 Parity failure first 64k RAM
2-_-_ Faulty Memory
3-1-_ Faulty Motherboard
3-2-4 Keyboard controller Test failure
3-3-4 Screen initialisation failure
3-4-1 Screen retrace test failure
3-4-2 Search for video ROM in progress
4-2-1 Timer tick interrupt in progress or failure
4-2-2 Shutdown test in progress or failure
4-2-3 Gate A20 failure
4-2-4 Unexpected interrupt in protected mode
4-3-1 RAM test in progress or failure>ffffh
4-3-2 Faulty Motherboard
4-3-3 Interval timer channel 2 test or failure
4-3-4 Time of Day clock test failure
4-4-1 Serial port test or failure
4-4-2 Parallel port test or failure
4-4-3 Math coprocessor test or failure
Low 1-1-2 System Board select failure
Low 1-1-3 Extended CMOS RAM failure
Feb 19, 2009 | IBM ThinkPad T40 2373 Notebook
At POST I get 2 short beeps
it depends on the bios chip maker Here's some other beep codes:
for Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly
Short continuous beeps: Bad power supply
AMI BIOS:
1 short beep: DRAM flash error
2 short beeps: DRAM ECC check error
3 short beeps: DRAM detect error
5 short beeps: CPU error
6 short beeps: Keyboard error
8 short beeps: Video card error
1 long and 3 short beeps: Bad DRAM
1 long and 8 short beeps: Video card error
Invoking Beep Codes
If the computer is actually functioning and the computer beeps continuously, then there is a problem with a voltage on the power supply being incorrect or the CPU overheating. IMMEDIATELY go into the BIOS and check CPU temperature, fan speed and voltages
BIOS Beep Codes
Annoying isn't it? You have built your computer you switch it on and then nothing happens except a few beeps from the PC speaker. Frustration sets in as you try to figure out what is wrong with it. If you didn't already know the computer has already told you the problem. It can't speak of course but it can direct you to the problem. Its all in the beeps. The BIOS can recognise when the problem occurs and sends a signal out to send a certain amount of beeps through the speaker. These beeps then tell you the location of the problem.
Unfortunately not all the BIOS' use the same codes as each other. Two of the main BIOS manufactures AMI and Award (now Phoenix) have different codes for there errors.
AMI BIOS
# of Beeps Error Description
1 Refresh Failure The memory refresh Circuitry is faulty
2 Parity Error Parity error in the Base (1st 64K) of memory
3 64K Base Memory Error Memory error in the base memory (1st 64K)
4 Timer Not Operational Timer 1 is not functioning (also caused by error in base memory)
5 Processor Error CPU error
6 8042 Gate A20 Failure Unable to switch to protected mode
7 Processor Exception Interrupt error The CPU on the CPU card generated an interrupt error
8 Display Memory Read/Write Error Video adapter is missing, incorrectly seated or has faulty memory
9 ROM checksum error The ROM checksum does not match that of the BIOS
10 Coms Shutdown Register Read/Write The shutdown register for coms RAM has failed
11 Cache Memory Bad The cache memory test has failed. Cache memory will be disabled. *** DO NOT enable it ***
With the first 3 beep codes, its well worth re-seating the memory just to make sure that it's in correctly. 8 Beeps is probably the most common in my experience. Can be caused by a badly seated Graphics card. If you have re-seated it then check with another Graphics card in the board.
Always check for loose components before sending the board back as this is the main cause of errors on the POST.
Award BIOS
Award states that they now only use one beep from there BIOS. This beep is one long beep and then two short beeps. This indicates a graphics card problem. Any other beeps should be treated as a RAM problem first and then the board sent in to be inspected.
The reason that the Award BIOS only uses the beep code for display problems is that it tries to display the error on-screen if at all possible. If the BIOS cannot initiate the display adapter then this causes the BIOS to make the beep code for a display error, which must be corrected before any other errors can be determined. Memory Test fails and hard disk failures etc will all be displayed on screen
IBM BIOS
The IBM BIOS works with Short and Long beeps as well as the Award BIOS. However the IBM one does still have codes to work from.
Beep Code Error
1 Short Beep Normal POST, System booted OK
2 Short Beeps POST Error - Code on Display
No Beep Power supply or Motherboard error
Continuous Beep Power supply or Motherboard error
Repeating short beeps Power supply or Motherboard error
1 short, 1 long beep System board error
1 long, 2 short beeps Display adapter error (MDA/CGA)
1 long, 3 short beeps Display adapter error (EGA/VGA)
Phoenix BIOS
The Phoenix BIOS works on a slightly more complicated manor than the others. It does display an error code for you and produce a series of beeps. This BIOS produces its beeps according to the hexadecimal code the error produces. The Phoenix BIOS has many different codes for its possible errors and so many different beep codes. Rather than list the entire section here, I have provided a link to the official PDF file containing the codes and how they are derived.
Phoenix BIOS Post Codes
System board errors should be looked at by a specialist, Again always try to re-seat components to ensure they are in correctly. If necessary take all components out except for the RAM CPU and graphics card, then try the system. Re-seating components is the number one fix for getting past the POST screen. One badly seated components can cause the entire system not to function. so pick out your bios and follow the steps above to diagnose .hope this helps
Jan 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Display problem
The most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
the vga board has failed, its a very common problem in acer laptops, you can get a replacement part from www.acerparts.com im not sure if they ship into us but for europe thats where I get my parts.
my acers vga failed two times, ones within warranty and 12months after that, I have to say that acer products are really bad quality, I'm not sure about the latest models but from what I've seen the vga chipsets have real issues with the motherboards and keep failing over and over again.
I have not looked inside your model but the vga is either integrated into the motherboard = that means the repair will cost the whole motherboard, better to buy a new one.
if your model has a removeable vga like mine does, then you can consider changeing it to a new one. contact acer parts.
One of the covers in the bottom is the memory, one is network and last one I don't remember.
here are the contact details if your acer is out of warranty
http://www.acerparts.com/contact_us.php
The parts for your model are at http://www.acerparts.com/index.php?cPath=561_562_1064
you will have to contact acer parts directly, it may be that the vga is build into the motherboard or then the vga parts are not listed.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 29, 2008 | Acer Aspire 5570-2758 Notebook
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
or this might help
AMI BIOS
AWARD BIOS
Pheonix beep codes
1-1-4 BIOS failure
1-4-2 Memory error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
HP Pavilion dv9000z Notebook Logo
248 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
