Question about Akai LCT3201AD 32 in. LCD Television
Hello, the DVD play fine but tv mode, continually says no signal and screen is blue. Please help
Posted by Kathy jordan on
George Persico
    Sergeant:
  • 231 Answers
You either have the DVD player plugged into the wrong input on the TV or the TV not set to that input. If using HDMI change the HDMI cord to another HDMI port on the the TV. In an Extreme case you have a bad connecting cord (either HDMI or other type.)
Posted on Oct 27, 2014
1 Related Answer
Anonymous
  • 40 Answers
SOURCE: green dvd
if dvd is a hdmi..and your using RGB cables..swap them around..it sounds like you have the cables misplaced..if that doesn't work..then swap out the dvd player and see if the replacement dvd player does the same thing
Posted on Jan 27, 2008
No signal to tv when dvd or vcrs is off
Assume no signal u mean no digital tv ?and what looses time and channel?do u recieve tv broadcasts via a box or is it built in?if u can recieve channels via dvd recorder i would assume where ever it gets them from needs to be connected to tv also.u dont say if its hdmi leads.scart or coax rf type.more info please
May 23, 2016 | JVC DR-MV5S DVD Recorder/VCR
Hi we have lost all channels of our hisence tv just blue screen saying no signal please help had channels yesterday
Nothing to worry, You change to AV mode to TV mode and wise verse,
If nothing happen then call the service center, It only two months old.
Jul 23, 2012 | Hisense LCD1504 15 in. Television
Soniq tv with built in dvd player says no signal on dvd mode
DVD unit has gone to dvd heaven. Not cost effective to repair. See if you have inputs so you can use an external player.
Feb 20, 2012 | Televison & Video
No Signal when in DVD mode
Make sure the leads are fully in both tv and dvd ends.Also are you on the correct av channel
Jan 23, 2010 | Televison & Video
While watching blue ray, the receiver loses the Signal
check the continuity of the AV Cables and check for any loose connection/dry solder in the connectors
Jul 13, 2009 | Yamaha RX-V861 Receiver
Sunia LTD-1510 TV/DVD-problem w/ TV signal and sound
Do you have a schematic diagram of TV mine is broken as well
I have two of them
Tracy
[email protected]
Mar 09, 2009 | Wanlida Group LTD-1510 15 in. TV/DVD Combo
Ps 3 no data
Try holding the power on button down until you hear a series of beeps, each one representing your ps3 switching video modes. try this until you get a picture on your screen, then you can use the options to set it to your tv's resolution. I've seen this same problem often from people holding the button when they turn it on :3.
Hope this helps.
Mar 26, 2008 | Sony Playstation 3 (PS3) Console
Stuck in Progressive Scan Mode...please help!
There should be a switch on the DVD player that is makred 'progressive/interlaced.' You need to flick this switch til it says interlaced, as obviously your TV cannot view progressive signals. It may be on the back of the player, or under a flap on the front.
Feb 04, 2008 | Televison & Video
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
TV/Cable will only play after inserting DVD
ya service is better its lose connect the tv controlpower
Dec 27, 2006 | JVC AV-27D303 27" TV
Akai LCT3201AD 32 in. LCD Television Logo
133 people viewed this question
Top Akai Televison & Video Experts
Marvin
Marvin
matt martin
matt martin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
