Question about Saws
The Target wet saw TA10100 is shutting down immediately after starting up. Anyone know the part that is causing this. We have replaced the off/on switch and repaired a wire to the switch with new conn
Tile Cutting machine is shutting down after it starts up. Who knows what is causing this? We need to finish an outdoor project before the winter sets in.
Posted by Frances Simon on
  • Frances Simon
    Frances Simon Oct 30, 2014
    I will now answer my own question. I found the part which resolved the problem. The capacitor which cost about $15.00 has resolved the issue.
Tim Marx
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
Check where your power cord goes inside the saw to the motor. All that wrapping the cord around to pack it up sometimes works it loose. Other wise id take it to a elec motor shop for a new motor, Last one i got i think it was $40 installed. Targets arent' cheap so its worth just putting a new elec motor in it.
Posted on Mar 17, 2015
5 Related Answers
Joe Hogan
  • 10865 Answers
SOURCE: crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Posted on Jan 28, 2009
chad bigger
  • 29 Answers
SOURCE: Tile Saw Troubleshooting
if your blade is newer or even well used,one way to make it cut better is find a used brick or a piece of a concrete block and cut through them,what really works best is a carborundum stone that setters use to hone cut edges of tile,you can get 1 at any tile store or home depot for 5 bucks. another trick is to lightly pull up on the table towards end of cut, if they keep breaking at end of cut, and you have the gauge set simply flip tile up side down and start your cut then back it off flip it over and cut through. all saw cuts leave minor chips on cut edge, we always stone cuts. cutting a brick cleans debris off blade. MAKE SURE WATER IS PRESENT WHEN CUTTING
Posted on Mar 31, 2009
chad bigger
  • 29 Answers
SOURCE: target tilematic ta10100
target customer service 800-288-5040
Posted on Jul 15, 2009
Dabunker
  • 8 Answers
SOURCE: tile saw not cutting straight
Sometimes a blade that is set deep enough will walk in this manner, especially if it is a thin kerf blade like the MK Hotdog blade.
Also, a blade which has worn unevenly will do this too.
Posted on Jul 22, 2010
Richard Crate
  • 157 Answers
SOURCE: need manual for 7-inch wet
Hello. Found the manual for you at:
http://www.northlandconstruction.com/products/4125/techsheet/QEP%2060087%207in.%20Wet%20Tile%20Saw%20Brochure.pdf
If this helped, please rate a four thumbs on this answer.
Thank You.
Posted on Mar 23, 2011
Does anyone have a link for the assembly manual for this product? We have received it without any.
what kind of wet saw is it? Target? MK? Chicago? there are many different types of saws. 7 in 10inch blades (what i use)
Mar 06, 2015 | Saws
I own the bench top Scheppach m90106 bandsaw. The kevlar band in the bottom of the saw that connects the motor to the actual blade wheel has become lose, causing the saw to lose power almost immediately...
I can't find any good source of manual of your saw. I wish I can help you. I don't know kevlar band. Try calling the technical rep of the manufacturer. They should be able to assist you with that.
Sep 12, 2013 | Saws
My target wet saw, on top of the motor has a part in it that overheats due to getting wet, there are two wires soldered. one labeled E, going to the motor,it seems to be an overload device possibly? I was...
We are currently experiencing a problem with the target TA10100 wet saw. It will start up and immediately shutdown. The local authorized tool repair said that the part encased on the top of the Baldor motor is called a capacitor. we have yet to find out if this is the cause of the problem. Hope the information helps you because so far it hasn't helped us.
Mar 08, 2010 | Target Saws
Need a wiring schematic for a dual voltage masonry saw motor. it s a baldor motor on a target saw
http://us.husqvarnacp.com/
drop down menu "service"
click "service literature"
click "old target, dimas, partner literature"
enter model number
pdf has basic wiring diagram page 4 or so
Dec 12, 2009 | Target Portable Masonry Saw PS1411S...
After riding a short time the engine kicks out turns off. Shortly after, I am able to turn the engine back on with key. I have a HD, 2000 Heritage Softail Classic.
after it shuts off, are you able to turn the engine over as if trying to start it? does it just turn over and not fire? or will it turn over at all? if it does turn over after it shuts off, immediately pull the plugs and check for spark. and also see if the plugs are wet with fuel.
Jun 03, 2009 | 2000 Harley Davidson FLSTC Heritage...
Wobble blade /rough cuts
You may wanna check the Conveyor Cart Wheel. Replacing this wheel maintains smooth rolling action which contributes to straight, chip-free cuts.
It costs for only about $28.72. Here, you may check this link if you wish to buy the Conveyor Cart Wheels:
http://www.diamond-blades.net/target_tile_saw_access.html
Unfortunately, I couldn't find any service center where you can bring your Target Tile saw for repair. But you may check the manufacturer's contact number on the user's manual.
Have a great day!
May 30, 2009 | Target Saws
How do I change the saw blade?
i have been doing tile over 20 years, I've never seen a blade that wont come off , on a great saw like target,or any other professional saw. that saw has a 10 in blade,inspect by lifting the blade gaurd so you can see the nut holding blade on, take a cresent wrench put it on the nut hold the blade with ur left hand and hit the wrench with a rubber mallet. It will come rite off,the nut does not have to be super tight,because it could warp the blade when cutting tile and it puts pressure on the bearing,inspect the motor by turning it on without water pumping it should be pretty quiet,it has a baldor 1 1/2 hp motor awsome motor.good luck
May 01, 2009 | Saws
1997 Crown Vic blows radio fuses
The quickest way to find a short circuit is by putting a bulb in place of the fuse. Anytime the time the bulb lights there is a load. And if the load is a shorted wire the brightness of the bulb will give you a hint. So while you're at it, finding a 'short' is a quicky...keep your eyes on the bulb. gotcha!
Sep 24, 2008 | 1998 Ford Crown Victoria
Saws Logo
712 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
