How do I reset an Officejet Pro 8630 to eliminate all the settings that were set and locked by an employee that is no longer here?
Posted by Ron Merritt on
David Harrelson
  • 5,440 Answers
Should be an option in the menu to reset to factory defaults.
Posted on Oct 27, 2014
Testimonial: "There is no way of accessing the menus...each time we try, we are greeted with: "These features have been disabled by user XXXX. To unlock these features or to make any changes to the current settings of the printer, please run the configuration utility from the desktop." When you run the configuration utility, you are asked for User XXXX's password...set things up HER way, and lock everyone else out!"
3 Related Answers
Curtis Richner
  • 461 Answers
SOURCE: Want to set Draft as Default Print Setting
Under Printers and Faxes in Control Panel (Classic View) right click on the printer and select properties then under Printing Preferences set Draft and click OK - this will now be the default setting.
Posted on Dec 11, 2008
jimfernbank
Jim Fernbank
  • 31 Answers
SOURCE: How to set date/time on HP Officejet Pro L7680
Instructions are on this web page:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01566785&lc=en&dlc=en&cc=us&product=2512009&rule=29401&lang=en
Posted on Mar 25, 2009
Anonymous
  • 10 Answers
SOURCE: We have a 7680 HP OfficeJet Pro and the last line
got to control panel, click printers, right click on printer and select properties, go to ports tab and unclick 'enable bidirectional support' box or see this website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Posted on Oct 02, 2010
MY HP OGGICEJET 8610/8620/8630 KEEP ON JAM
Try these steps to resolve paper jam issues:
Dec 06, 2016 | HP Office Equipment & Supplies
Tip
Upgrade your printer and continue to refill your own ink cartridges
I just had my HP 8600 document feeder fail. This problem part cannot be ordered for replacement, and to have it repaired will cost almost $200. Well a brand new one on sale is only $250. And better yet, upgrade to the HP Officejet Pro 8630, since HP will no longer be manufacturing the 8600.
I have saved hundreds of dollars, refilling my own cartridges. I upgraded, after I learned that the newer model uses the exact same ink cartridges. So, I am on my third HP Printer, and I have purchased only one set of cartridges in 3 years. I have refilled my color cartridges at least 8 times. They need refilling more frequently than the black. (The black ink cartridge is twice the size.)
In addition, I purchased a three year extended warranty for $20 or $30. If anything happens to this printer in that time, it will be replaced automatically, and I will not have to pay for shipping.
In essence, I am in position to have used the same set of ink cartridges for 6 years. I only put my new cartridges in after I have refilled the empties. After the printer resets, I pull them out and put in the refills. So you see, my printer came with a set of cartridges, and I purchased one extra set, for resetting the printer after refilling the cartridges.
I suggest to really control your costs, consider buying a quality printer, that will be good for years of service, add a service contract, and refill your own cartridges. If you print as much as I do, you are realize a significant savings in the cost of ink.
I know that I have saved a minimum of $360. Add the cost of inconvenience and going to Walmart for refills, and you may be realizing a savings of $150 per year, just for refills.
Good luck, and plan ahead.
on Mar 04, 2015 | HP Officejet Pro 8600
Every time I go to print a single 1 page pdf, my printer prints backwards. How can I get it to stop printing images in reverse?
Open up the printer preferences from "Devices and Printers" and click to print in default settings, then apply and OK
Same in PDF Viewer
Dec 01, 2015 | HP OFFICEJET PRO 8630 eAiO
Looking for a service manual
I hate to say it but good luck. HP makes very little available for the standard officejet products in terms of parts or manuals. They mostly treat these as return to HP for repair or if under warranty they do a exchange for a refurbished unit.
Aug 15, 2015 | HP OfficeJet Pro 8620 Wireless All-in-One...
How do i refill my hp cartriges in my hp 8610 printer step by step.
All refill sets, come with a good description. But before you buy ink, make sure your cartridges can be filled and the chip can be reset. So you won't end with filled and unusable cartridges and dirty hands.
Look here to see how things go:
Ink Refill Kit For HP Officejet Pro 8610 8620 8630 8625 8615
Mar 29, 2015 | HP Officejet Pro 8610 Wireless All-in-One...
How to reset HP Ink Levels Printer hp officejet pro k8600
the only way to reset ink levels is to replace the cartridge(s). If you're refilling, you need a second set of cartridges and use them in rotation with the first set.
Aug 29, 2014 | HP OfficeJet Pro K8600 Printer
Printer has operated troublefree in the past. Now the wireless con nection is off and will not reset.
Have you tried this?:
Touch Settings - Tools - Restore Factory Defaults
Aug 02, 2014 | HP Officejet Pro 8600
Cannot adjust the quality settings on our Fuji S3 Pro
have you tried the reset to factory settings? in your user manual it tells you how to reset everything.
Apr 20, 2009 | Fuji FinePix S3 Pro Digital Camera
363 people viewed this question
Marvin
Marvin
