Question about Jacuzzi Home
How do i take apart and fix my general electric jacuzzi pump 1986 modle number7jc-un2
How do you take the pump off the moter on model number7jc-un2
Posted by brian watker on
2 Related Answers
boysor2933
Boyet Soriano
  • 293 Answers
SOURCE: I have a Jacuzzi Jet Pump Model 7C-S/B. Not Working
Check the breaker that supplies power to the unit. If it is in tripped position, check if the motor is grounded ( continuity between terminals and motor body), check for shorted windings (infinity resistance value between the winding phases), and finally check if the pump is stuck up due to debris or defective motor or pump bearings.
Posted on Jun 11, 2009
TerryH
  • 111 Answers
SOURCE: HAYWARD POOL PUMP MODLE; C48L2N134B1 1/1/2 HP ALL PARTS TO RE BUILED MOTER
Hi, you can buy most replacement parts for an A.O Smith motor here.
Posted on Feb 05, 2012
MY CAPACATOR FOR PUMP ON JACUZZI MODEL DC25 BURN
contact the MFG's website tech support
Dec 29, 2014 | Jacuzzi Home
The blower fan on my AC/Heater isn't working properly.
check the capacitor on the moter or just replace 12.00 bucks. if it doesnt work you need new moter.
Oct 23, 2012 | General Electric GENERAL ELECTRIC...
How to adjust fuel volume at liftpump
Thank you for asking me to help you with your problem. However, your vehicle is too old for me to look up the information that you are asking for.
Dec 12, 2011 | 1986 Toyota Land Cruiser
Need new impeller but dont know model number
the impeller you need is 05-3818-01 for a 2 hp full rate pump model 2MF-S2
it will be 05-3819-00 if your modle number is 2UMFS-S2
you can find them at US Parts Center
Aug 23, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
I HAVE A MAGNUM FORCE PUMP. iT WAS RUNNING THIS
It could be the capacitor again, but most likely if it stopped while running, its not that, unless you had a brief power failure. The motor may have a built in thermal overload which turned the pump off. If it only humms then it could either be locked up by something in the impller, or could be the bearings in the motor have failed. If the motor doesn't smell "burnt" then you might stand a change to disassemble the pump. Disassemble the motor and replace bearings. Replace the mechanical seal while you have it apart. OR you could buy a new motor, as it is 10 years old.
Jul 05, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Moter does not turn ON
If the tub has an push in off/on button, the problem is the air switch which is attached at the back of the motor in a black box. If the control panel has touch buttons, the problem lies in the control box that controls the pump or the pump itself which might be seized. If you can unplug the pump from the control box, it can be plugged into an outlet to see if the pump works. Unless you are mechanically inclined it would be best to leave this to a pro.
Sep 06, 2009 | Jacuzzi LUMINOSA WHIRLPOOL SINGLE SPEED...
Jacuzzi pump not pumping
I would probably say that the pump is clogged up or frozen. The motor humms until the heat sensor clicks it off. Try taking apart the front of pump and see if it turns and you should see the problem. Parts are available at most pool stores. Pumps are usually cheaper online.
Jun 25, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Some of jet points inside jacuzzi are not mixing air with water
the jet are pushed by the impeller (it's like a fan blade) run by a moter water is pushed through the plumbing and out the jet head . when you open an air valve air is mixed in .
Feb 03, 2009 | Pool & Spa
Dishwasher pump not working
if you go here http://www.searspartsdirect.com/partsdirect/index.action and enter your model number without any spaces you can get a parts list on that page you will see show diagram it will give you a blueprint of the pump moter assembly
Jan 30, 2008 | Dishwashers
Home Logo
378 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
