This is a fairly new Shaver 3-4 months old.It's my Father Shaver any way a few days ago it would charge .After that nothing lights up at all,if I press the Power switch a Red Light Flashes.I've checked the power supply with my meter it's putting out 12.9v.I checked also with the meter continuituy there I got resistence readings.Can someone give an idea of a possible solution.Thanks LCM
Model 7526 is not a new shaver. It was made about 8 years ago. If no lights illuminate when the power cord is attached, the circuit board is bad. Unfortunately, Braun no longer makes internal parts for this model
If you like this shaver model and want a similar one, you will find one at shaveroutlet.com. This model uses the same shaving head as the 7526
http://shaveroutlet.com/braun-series-1-195s-mens-cordless-shaver.html
SOURCE: Powers on, screen flashes Akai screensaver and then shuts off
Take the unit into the service center - have the service center diagnosed the problem - they will order the part - but the parts are not available - DONT WAIT - The manufacturer must exchanged the unit because the the manufacturer must provide the parts for up to 5 years by law after the the tv is manufactured. Have the service center provide you with a workorder stating the television is not repairable because the parts are not available - then call 800-726-4405 - they will start hte process to exchange the televsion - LONG PROCESS to get an exchanged television
SOURCE: Shaver will not charge or clean in the base
All you have to do is take the base apart. Turn it upside down, and there are two plastic clips on the rear portion of the base. Press them in with a key or screwdriver and wiggle the base a bit to remove the inner portion from the outer shell. Make sure you unplug the unit and remove the cleaning cartridge before doing this. Once it is apart, place a small wedge underneath the portion of the electric contact that sticks out to touch the shaver, and press the back of that portion out so that it slightly bends the contact strip and makes it stick out a little further. Then remove the wedge and put the base back together. It will work again, as the contacts can now protrude to touch the shaver and run the cleaning and charging cycle.
SOURCE: Braun 5614 rechargeable cordless shaver light flickers
Your batteries are starting to degrade, but the good news is they're still holding a charge for a week, so you really don't need to rush to replace them at this point.
The flickering of the charged indicator is normal, as the shaver is still plugged in and the batteries are fully charged. The flickering is due to the batteries chemicals breaking down, and as such, the charge cycle keeps "topping" them off while it's still plugged in.
When you finally aren't able to get a decent amount of cordless operation and run times from your shaver, then you'll want to get them replaced, whether you decide to do that yourself or have it done by a professional service center, is up to you.
Here's a reference for your future use. www.electricshaver.com carries replacement (factory OEM) batteries for most brands of shavers and they also will provide the repair/replacement service for you, should you decide you don't want to do it yourself. You can also give them a call at 1-888-476-1785 and request a price quote, etc.
Anyway, your shaver is working fine and all you need to do is make sure you're not letting the shaver stay plugged in and charging constantly for more than a day, since any "extra" chargind isn't doing anything except keeping the batteries at a constant state of charge. Heat is a byproduct of charging and discharging any battery and as such, you want to allow for a cool down period before recharging them.
I tend to use my shaver until it is almost completely discharged before recharging it. By doing this, you can get the longest working life out of your batteries before you'll have to replace them.
Hope you find this Very Helpful and best regards!
Testimonial: "very helpful"
SOURCE: I have a Polaroid TDA-03211C the red power light
How is the power supply module?
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
