Question about Samsung RS261MDBP Side by Side Refrigerator Ice and Water Dispenser -
My SamSung RS261MDBP is not dispensing ice, it humps when I try to get ice so I thought the motor was the problem. I replaced motor but it still doing the same thing... What could be the problem? tha
My SamSung RS261MDBP is not dispensing ice, it humps when I try to get ice so I thought the motor was the problem. I replaced motor but it still doing the same thing... What could be the problem? thanks in advance
Posted by Jay Liu on
Aaron Cantwell
    New Friend:
  • 12 Answers
Jammed auger or blocked chute.
Posted on Nov 11, 2014
How to take the panel off to replace dispenser system DA97-12095a
Sorry my friend. Can't explain how to due it. It takes a lot of pratice on units to learn how to remove them. But you will need a putty knife to slide into the covers. Very very easy to break. Maybe check YouTube.
Oct 29, 2015 | Samsung RS261MDBP Side by Side...
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
Ice will dump and refill when hitting reset button, but wont dump an fill on its on
Hello Jamie;
My name is Peter. I am a retired field service refrigeration technician.
It sounds like your have a bad ice maker sensor. On the ice maker mold is a long white coated wire. This is a temperature sensor. The sensor tells the ice maker control module that the water in the mold is frozen and to harvest the ice cubes.
The flex mold ice maker that you have is not repairable.
DA97-08241C Cost $135.00
Dec 11, 2014 | Samsung RS261MDBP 26 cu. ft. side by side...
Frigidaire is not dispensing ice
Good Afternoon, thank you for your inquiry!
I see you are having trouble with your Frigidaire refrigerator dispenser not dispensing ice. Do you hear the auger motor running when calling for ice? If you do not, the dispenser may be jammed or the refrigerator has a faulty auger motor. I suggest try clearing any ice that is blocking the ice chute, removing any frozen ice or obstructions, verifying that the water valve or fill tube is not frozen. If any proves to be ineffective contact a professional to move forward accurately.
Best regards! - Z
Jul 11, 2014 | Frigidaire Freezers
Samsung model rf4287hars only dispenses water when ice lever depressed
3b662ccb-018c-4390-ab7a-74a2025960df.jpg 3d562c7f-18a6-4fa7-9993-373c8c5d3c7f.jpg 763378c4-5f13-435a-aac3-b67d9041b031.jpg
First photo shows paddle assembly that can be purchased you need to got to Sears web site to find part # other wise you will have to buy the whole circuit board assembly hundreds more than the paddle assembly. The circuit board and paddle assembly is removed buy removing screw on inside of door and pulling it out be careful it seems strange but it just pops out. The paddle assembly slides on to the circuit board assembly look close and take your time to slide it off I thought I was going to break mine but did not and save me big money.
Second photo shows tab for water dispensing still there.
Third photo show ice dispensing tab broken and missing.
If you leave the assembly plugged in press the micro switch for the ice dispenser and see if it works most likely the tab has broken and is what hits the switch telling the door to open and ice dispensing screw to push ice to the door. Hope this helps
Mar 04, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
Our refrigerator is making the bell sound when the door are close
if it has belling system ,it bell alert when the door closed or otherwise you read the catalogue there must be written of this problem solution.
Mar 23, 2013 | Samsung RS261MDBP Side by Side...
The ice maker makes a loud racket unless the freezer door is open.
You have an object jammed in ice makers path. The freezer door has something on it that is pushing into the ice maker perhaps.
Feb 08, 2013 | Samsung RS261MDBP Side by Side...
Samsung RS261MDBP Side by Side Refrigerator Ice and Water Dispenser - Logo
263 people viewed this question
Top Samsung Freezers Experts
Tad
Level 1 Expert
Harrie
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
