Question about Gentex 2008 Kia Sedona - All Sedona models - K2 Auto-Dimming Rear View Mirror
<!-- from fixya rte -->Code P2135 Kia sedona 2008 - Gentex 2008 Kia Sedona - All Sedona models - K2 Auto-Dimming Rear View Mirror
Posted by Tony Mootispaw on
Allen
Thanks you ang i try to replace throttle position sensor
Posted on Apr 04, 2020
Behind_Blue_Eyes
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
- Faulty Throttle Position Sensor (TPS )
- Throttle Position Sensor (TPS ) harness is open or shorted
- Throttle Position Sensor (TPS ) circuit poor electrical connection
- Faulty Powertrain Control Module (PCM)
Posted on Oct 26, 2014
Replaced roof dvd players side bulbs lights in kia sedona 07 plate now they only work when switched not automatically when door opens?
Kia Carnival & Sedona Forum [Archive] - Kia Forum - Kia-Forums.com
www.kia-forums.com > Kia Forum > KIA Models
Jul 8, 2006 - [Archive] Discussion area for every generation Kia Carnival and Kia Sedona. ... 2006 SEDONA EX front and rear blowers dead · 2007 Kia Sedona LX 3.8L... out of the intercooler air intake · 2002 Kia Sedona Front heater will only work with a slap! ... 2003 Kia Sedona, Will Crank but not start after replacing MAF, crank and ... Kia Carnival & Sedona 2006+ [Archive] - Page 3 - Kia Forum
Apr 11, 2012
Kia Carnival & Sedona (2002 - 2005) [Archive] - Page 5 - Kia Forum
Jul 24, 2008
Kia Carens & Rondo Forum [Archive] - Page 2 - Kia Forum - Kia ...
Aug 15, 2007
More results from www.kia-forums.com
[PDF]2006 Sedona Owner's Manual - Kia Canada
www.kia.ca/.../ownersmanual/2006_sedona_Owners_Manual_E... Kia Motorsrecommended special tools, genuine Kia replacement parts and .... Room light main control switch.....3-123 ...... work properly, the power sliding door and ..... fuel only. • Check to make sure the fuel filler cap is securely closed after refu- .... roof, you have to reset your sunroof sys- ...... bulb check when you turned the ignition.
Jan 30, 2016 | Kia Cars & Trucks
Kia sedona compressor clutch does not turn?
check for fuse and relay problems in the ac circuit. disconnect the wire near the ac clutch and use a test light to see if there is power there. Remember that there are 3 units that will stop the clutch from working. Low pressure switch, high pressure switch and the thermostat. Best take it to an accredited ac specialist shop for a test of the system as you may have a leak and all the gas is gone.
Aug 31, 2014 | 2008 Kia Sedona
How to replace the timing chain on a 2006 kia sedona
The video at the link should help. You can alos download the repair manual free at the KIA owners site 2008 Kia Sorento 3 8L timing chain marks
Dec 11, 2012 | 2004 Kia Sedona
How to solve KIA Sedona audio code
notify dealer will need radio number radio code is a security code
Jan 23, 2010 | 2002 Kia Sedona
Gentex 2008 Kia Sedona - All Sedona models - K2 Auto-Dimming Rear View Mirror Logo
253 people viewed this question
Top Gentex Optics Experts
Lawrence Oravetz
ray gallant
Bill Boyd
Are you a Gentex Optic Expert? Answer questions, earn points and help others
