SOURCE: hi just had new dishwasher
Rinse aid is always needed for ALL dishwashers to properly operate.
SOURCE: Diplomat Dishwasher ADP8352 Will not complete wash Cycle
My Diplomat ADP8352 when running a cycle it will run for ages, doesn't seem to get hot. If i switch off the m/c then switch it on again it dumps the water left in the m/c?
any ideas?
SOURCE: flashing programme lights
Hi
Thanks for using FixYa. That means the control sensed that the heater in
the D/W did not operate 3 times in a row. So the unit locks out. First remove
the kick plate and you may have to pull the unit out from under the cab, but
check your heater. Use a meter to see if it reads open; if so orders a heater
assay it will come with a new control replace it too. If heater checks good
then press in sequence normal wash, heat dry, normal wash, heat dry, normal
wash, heat dry three times within 6 sec and all the lights will come on then
hit cancel. What that did is reset the control and clear that fault. Keep in
mind that D/W does not heat its own water and incoming water temp should be
120. The D/W will maintain that temp. When starting your D/W first turn on your
hot water till it gets hot then start your D/W this ensures your unit fills
with hot water and not cold
Please do rate the solution and revert for further
assistance.
Thanks
Rylee
SOURCE: my Diplomat dishwasher ADP8352 keeps stopping
Switch off the machine at your plug end and switch ON.
Check incoming water flow. Check and fill rinse-aid liquid in the dispenser. Check dish washer salt dispenser and fill.
These are the only actions an user can try.
