Question about AcuRite Indoor / Outdoor Thermometer
The temperature reading doesn't change and is blinking. I have changed the batteries but nothing changes. Suggestions?
Posted by Eloise Aho on
  • Wilma Harris
    Wilma Harris Oct 27, 2014
    I have the same problem. Yes, I changed the outside unit batteries, reset it, still not outside temp or humidity. Mine is Model 16870
AcuRite
    New Friend:
  • 20 Answers
The outdoor temperature flashing is generally related to a low battery in the outdoor sensor. Check to be sure you are using fresh, good quality alkaline or lithium batteries in that outdoor sensor.
Posted on Oct 28, 2014
Chris Hunt
    Genius:
  • 1,342 Answers
Have you changed the batteries on the outside sender unit?
Posted on Oct 26, 2014
Spa-N-A-Box not heating
It is possible but I suspect that the heating element is failed.
Jun 25, 2013 | Comfort Line Pool & Spa
I have got a 2000 dodge ram 2500 cummins 4x4 that the Temperature Gage doesn't move and the Heater doesn't get very warm. I have changed the Thermostate, with no change......
Have you checked the block pressure.There was a problem with the impellor coming loose on the water pump which causes low block pressure and reduces circulation.You should also check the vent line to the rad and make sure the jiggle pin in there is ok it sounds like the system may be air locking
Jan 27, 2013 | Dodge Ram Pickup 2500 Cars & Trucks
02 z71 rebuild and new converter install now I have nothing and push button 4x4 in 4 high and doesn't change like it should any suggestions
I really don't understand the base problem here, the vehicle doesn't move? Please clarify this.
Oct 25, 2012 | Cars & Trucks
I've changed battery in isys+ pre amp on vintage vec500 and now tuner doesn't work (it is blinking green on note tuner no matter of tune and no note letters showing - blank screen)
Is the battery installed in correct polarity? If so- try rotate it in position to rub through potential corrosion.
Since it has a remote battery, it would not hurt to look at the installation to make sure no wires are broken. Especially the ground wire to the pickup.
It might also be a good idea to apply some contact cleaner to the output plug since it is in the power circuit. Cycle the plug in and out a few times to clean the contacts. Also some contact cleaner to the preamp controls would be useful.
Be aware some lubricants may contain silicone and that can interfere with wood finishes or repairs to the finish in the future.
Apr 06, 2012 | Music
How do I change the temperature reading from Celsius to Fahrenheit?
with the switch in the 'lock' position, hit the C/F button (also labeled as the 'min' & 'date' button)
Dec 30, 2011 | Elgin Travel Alarm Clock
My 2004 GMC Envoy has two trouble code readings of 106 & 128. But the light will come on for a while then it will stay off for a while. The auto parts compny that should me the readings said it could...
Hello there,. Below is the detailed information which you asked for.
Please do not forget to rate me!!
Best regards
Ck
P0106 - MAP/Barometric Pressure Circuit Range/Performance ProblemOBD-II Trouble Code Technical Description
Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
What does that mean? The Powertrain Control Module (PCM) uses the Manifold Absolute Pressure Sensor (MAP) to monitor engine load. (NOTE: Some vehicles have a Barometric Pressure (BARO) sensor that is integral to the Mass Air Flow (MAF) sensor and do not have a MAP sensor. Other vehicles have a MAF/BARO and a redundant MAP sensor where the MAP sensor functions as a backup input in case of MAF failure.) The PCM supplies a 5 Volt reference signal to the MAP sensor. Usually the PCM also supplies a ground circuit to the MAP sensor as well. As the manifold pressure changes with load, the MAP sensor input informs the PCM. At idle the voltage should be 1 to 1.5 Volts and approximately 4.5 Volts at Wide Open Throttle (WOT). The PCM looks for any change in manifold pressure to be preceded by a change in engine load in the form of changes in throttle angle, engine speed, or Exhaust Gas Recirculation (EGR) flow. If the PCM doesn't see any of these factors change while detecting a rapid change in MAP value, it will set a P0106.
Causes A P0106 could be caused by:
  • Bad MAP sensor
  • Water/dirt intrusion affecting MAP sensor connector
  • Intermittent open in the reference, ground, or signal wire for the MAP sensor
  • Intermittent short in the reference, ground, or signal wire for the MAP sensor
  • Ground problem due to corrosion causing intermittent signal problem
  • A break in the flexible air intake duct between the MAF and the intake manifold
  • Bad PCM (do not assume the PCM is bad until you've exhausted all other possibilities)
Possible Solutions Using a scan tool, watch the MAP sensor value with the key on, engine off. Compare the BARO reading with the MAP reading. They should be roughly equal. The voltage for the MAP sensor should read approx. 4.5 volts. Now start the engine and look for a significant drop in the MAP sensor voltage indicating the MAP sensor is working.
If the MAP reading doesn't change perform the following:
  1. With the Key on, engine off, disconnect the vacuum hose from the MAP sensor. Using a vacuum pump, pull 20 in. of vacuum on the MAP sensor. Does the voltage drop? It should. If it doesn't inspect the MAP sensor vacuum port and vacuum hose to manifold for a restriction of some kind. Repair or replace as necessary.
  2. If there are no restrictions, and the value doesn't change with vacuum, then perform the following: with the Key on and engine off and the MAP sensor unplugged, check for 5 Volts at the reference wire to the MAP sensor connector with a Digital Voltmeter. If there is none, check for reference voltage at the PCM connector. If the reference voltage is present at the PCM connector but not the MAP connector, check for open or short in the reference wire between MAP and PCM and retest.
  3. If reference voltage is present, then check for existing ground at the MAP sensor connector. If it isn't present then repair open/short in the ground circuit.
  4. If ground is present, then replace MAP sensor.
Other MAP sensor trouble codes include P0105, P0107, P0108 and P0109.
P0128 OBD-II Trouble Code Technical Description
Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
What does that mean? This means that the engine's PCM detected that the engine has not reached the required temperature level within a specified amount of time after starting the engine. The intent of the P0128 code is to indicate a faulty thermostat. Similar codes: P0125
In determining the engine did not reach a "normal" temperature, it takes into account the length of time the vehicle has been running, the intake air temperature (IAT) sensor reading, the engine coolantmag-glass_10x10.gif temperature (ECT) sensor reading, and the speed of the vehicle.
Causes A code P0128 may mean that one or more of the following has happened:
  • Low engine coolant level
  • Leaking or stuck open thermostat
  • Faulty cooling fan (running too much)
  • Faulty coolant temperature (ECT) sensor
  • Faulty intake air temperature (IAT) sensor
Possible Solutions Past experience indicates that the most likely solution is to replace the thermostat. However here are some suggestions on troubleshooting and repairing a P0128 OBD-II code:
  • Verify coolant strength & level
  • Verify proper cooling fan operation (check if it's running more than it should). Replace if necessary.
  • Verify proper engine coolant temperature (ECT) sensor operation, replace if necessary.
  • Verify proper intake air temperature (IAT) sensor operation, replace if necessary.
  • If the above items check out good, replace the thermostat
Sep 24, 2011 | 2004 GMC Envoy
What is the best battery for my 2002 vrod
I would definitely go for the Harley recommended battery. HD has changed their sizes and you don't want a generic battery that doesn't fit properly or doesn't have the right amount of cranking amps
Jun 26, 2011 | 2002 Harley Davidson VRSCA V-Rod
My Black and Decker Firestorm 24 volt charger is not working
change batteries, your charger should indicate wheather you battery is good or noot on the pause inbetween blinks.
Aug 13, 2009 | Black & Decker Black And Decker FS24C...
AcuRite Indoor / Outdoor Thermometer Logo
594 people viewed this question
Top AcuRite Measuring Tools & Sensors Experts
Tom Chichester
Marvin
Marvin
Are you an AcuRite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
