Dishwashers Logo
Question about Kenmore Dishwashers
Old dishwasher, lock on light blinks all time
Model 665-15817990 serial # fj3302556-15817. somebody answered that saying to push this buttons in order. 1)high temp wash, 2)heated dry 3) high temp wash, 4) heated dry. don't have those buttons.
Posted by salvatore bottone on
Thomas Beaver
  • Kenmore Master
  • 2,119 Answers
Is this a Kenmore? If so here is Searspartsdirect. User and installation manuals, parts diagrams and parts lists and repair help.
KENMORE Dishwasher Parts Model 66515817990
Posted on Oct 26, 2014
5 Related Answers
Anonymous
  • 127 Answers
SOURCE: kenmore dishwasher ultra was quiet guard 3 model
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
Anonymous
  • 338 Answers
SOURCE: Clean light keeps blinking and I can't start a new cycle
That is a comon problem with that model. It is not sensing a temperature change in the water.
Push i believe it is heated dry and sani rinse going back and fourth between the two to clear the code and see if you can get it to complete a cycle. If it doesnt call sears and schedule service there is a service flash repair that should not cost you anything to repair the unit.
Posted on Nov 25, 2008
Anonymous
SOURCE: My Whirlpool Quiet Partner 111
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
Posted on Jan 28, 2009
Anonymous
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
Anonymous
SOURCE: Kenmore dishwasher blinking light
I have a solution. For Kenmore Dishwashers begining with model 587 and the flashing washing light.it will not start.
inside the front door there are two black and two white wires that lead to the handle. this connection is an on/off saftey for the door latch and if wet will short. The light is flashing because the machine thinks the door is open.
these connections on my machine are very loose. a needle nose pliers to tighten the crimps clean the prongs recconect hard reset at breaker box and you should be ready to go.
m
Posted on Nov 18, 2009
1helpful
Fisher Paykel DS605i single dishdrawer with a user-supplied integrate panel. There are three buttons on front. The left-hand button is power button; the center button is start/pause; and the right-hand...
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
2helpful
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Dishwasher won't start and the green 'clean light' is blinking
your computer has detected a problem , most likely with the water heating. its locked up. Try pushing the high tem wash buton and then the energy saver button , push them back and fourth a few times(some modles its 2 other buttons) This should actavate a service check cycle where all the lights go on. Let it do its thing, and cancle after a few mins. if it locks up again you need service.
3helpful
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
Lock On
To turn on the Lock
flashes 3 times.
hope this helps,
best of luck,
ttfn
2helpful
2answers
Dishwasher not responding
we have a 4 yr. old built in dishwasher,model #665-15812,the lock-on light is blinking,and the wash and rinse lights are on,but if we push start ,it won't,and if we push the clear button,it won't clear,it's like it's stuck ....we've tried un-plugging,etc....any ideas,on what to do??? donnie-sue79
2helpful
2answers
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Blinking quick rinse and lock on lights
Try holding down the "lock" button.It may be the way to unlock the problem.
2answers
1helpful
Maytag dishwasher blinking
try holding the lock button from three to five seconds if that doesn't get it try removing power for same time and advise
Jan 10, 2008 • Dishwashers
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
