I already know about the display high and lo functions. The display lo is still too dim. I'd rather not have the ambient light detection at all or fool the system in to thinking it's always in bright light conditions.
SOURCE: I have an older Bose Wave radio without a CD. Can
If it has another input then yes if not you will have to get a A/b switch.
SOURCE: how to connect my Bose Wave System to two outdoors Bose speakers?
It won't connect to externa l speakers directly but you could take the RCA output to an amplifier that drives them.
SOURCE: I have a Bose Wave radio AWRC-1g. The CD player
Yes you have a defective laser assembly. The 139 is a great price as buying the laser lens alone will cost you around 70 .Bose will also upgrade with any new software and will also provide you with a 1 yr warrenty.
SOURCE: CD not playing with bose wave system but same cd
The cd assembly is the issue, over a period of time the laser pickup becomes weaker until it can no longer read the disc, one possible solution is to buy a disc cleaning kit and follow instructions in an effort to recover the assembly. If that fails the only option is contact Bose for pricing since they are the only authorized service centre that work on their own products.
SOURCE: Wave Music system Multi-CD Changer
The unit has a power supply problem, no user servicable parts inside. Bose uses a thermal fuse built into the power transformer. Take unit apart and check for connection issues first, then look for a possible fuse, if none exist chances are it is in the power transformer, contact Bose for service.
