Question about Sansui 32" TV
MY PIP BUTTON IS NOT RESPONDING WAT SHALL I DO MY MOVIE SCREEN IS TOO SMALL.
Posted by SUNNY JOSEPH on
    Top Expert:
  • Sansui Master
  • 76,407 Answers
Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Posted on Nov 01, 2014
My vizio flat screen has screen stuck in top right
Your TV is in Picture in Picture (PiP) mode. The small picture is the previous live input. The bigger dark area is the current input where there's no live source.
Find the PiP button on the TV remote or via the TV's menus. Press PiP a number of times to cycle through the options. Stop when the picture is the size you want.
Have a read of your TV manual. Stuff like this is detailed in there.
Sep 02, 2014 | Televison & Video
HOW DO YOU TURN OFF PIP ON HP LC3260N
Hello, it's not PiP that's on , it[s a closed caption issue. the CC is in the text mode and is an easy fix. just press the CC button on the remote (it's located above the 1 button) till it says off on the tv screen, or if you use closed caption select CC1. this should take care of your problem......thanks, Terry
Sep 20, 2012 | HP LC3260N 32 in. LCD HDTV
Panasonic p50u20b - picture shrunk into top right hand corner of screen
seems you have found the PiP (Picture in Picture) if you still have the orignal remote press the pip button or the cancel button
Dec 28, 2011 | Panasonic Televison & Video
I have an LG 42LB5D LCD HD TV that has just developed a blank white screen for television (cable) broadcasts. The audio is still fine. The DVD shows up fine. And, the PIP small screen works. This occurred...
Try to use other dvd movie, if the movie play's normal try to focus in to your digital receiver their maybe only a loosed connection specially the input and output of your digital receiver.
Jul 08, 2011 | Televison & Video
Player has sound of the movie but the screen is just white no picture
There is a small button on top when the screen closes it turns off the display. While the movie is playing press the small button with a small pointing object and see if the display shows something on the screen for a few second and then off (you can sometime see the movie playing but very dim). then there is a problem with the switch not switching the display back to normal. Hope this helps...
Jun 02, 2011 | kawasaki PVS-10921 Portable DVD Player
I have a sony bravia 32`` and i have pip on my tv but i cant selectionate that what i need to do?
picture in picture means you will need a second input for PIP to work. For example you are watching a movie on a dvd player thru the bravia if your antenna is also connected that becomes your second input. Therefore when you select PIP a small screen will appear and you will be able to see the channel that was last set on that screen... hope this helps
Dec 31, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Picture inside a picture on my TV screen
The PIP (picture-in-picture) setting can easily be reversed if you look on your tv for the PIP button or for the same button on your remote. If neither of these works then you may want to check your TV's operation manual for the PIP setting .
Nov 26, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture in picture
i am not familiar with this model, but on most sets you will have a button on the remote to activate pip, when active you should be able to adjust channels on the small display with the remote and cycle through inputs. depending on the tv you will either have 2 inputs for your cable/sat/tv feed, or will have 1 with a dual tuner.
check the connections in the back for a second cable input, or hook up a dvd/vcr/game console/etc to test the pip.
start dvd or tape playing, press pip button to display the mini-screen, then use the tv/vcr or input button to cycle through the modes and see if one pops up. most tvs that have pip will also have a swap button on the remote, it may be labeled with text, or it may just look like one screen overlaying another, press that one to swap between displays.
hope this helps,
trin
Nov 16, 2007 | Samsung PCJ522R 52" Rear Projection...
Sansui 32" TV Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
