Sony CorporationThe headphone cord of headphones is an FM antenna, therefore, connect headphones to the (headphone) jack when listening to the FM radio.
WikipediaA tuner is a subsystem that receives radio frequency (RF) transmissions like radio ...Older models would realize manual tuning by means of mechanically ...
when you are 1 mile apart a 1.5 watt difference isn't going to make a whole lot of difference . Its when you start getting further away that the wattage and the modulation make the difference.
WELL FIRST OF ALL WHY DO YOU NEED TO TUNE THE RADIO AND SECOND UNLESS YOU ARE FIRMILLAR WITH A CB YOU CAN DO MORE DAMAGE BY TRYING TO TUNE IT THAN THE PROBLEM THAT IT MIGHT HAVE NOW> FIND YOU A GOOD CB SHOP AND LET THE PROFFESSIONALS HANDLE THE PROBLEM
From the main menu, select the icon that looks like a little radio To search for the next stronger signal, press and hold the up or down arrow To fine tune the frequency, briefly press the up or down arrow
From the main menu, select to enter radio mode. • The earphones cable acts as FM antenna. Manually tune a radio station While in mode, you can manually tune to a radio station: 1 To search for the next stronger signal, press and hold / . 2 To fine tune the frequency, briefly press / . Auto-tune preset radio station The auto-tune feature of GoGear Vibe helps you find radio stations and save them under the preset numbers. 1 While in mode, select [Auto tune] > [Yes]. »» The radio automatically tunes radio stations and saves the frequencies to presets. »» There are 20 presets available. »» To stop auto tuning, press . »» To exit radio, press and hold for 2 seconds. EN
Don't hook both antennas up. Co phased antennas only work if they are 8 feet apart and both tuned exact.
you will have to lower your mic gain to turn the talk back up.
If you only have a 1 mile range, I doubt you are doing 100 watts. Unless your antenna system is that bad, in which case you are going to blow out the radio.
Galaxies are nice radio's. I wouldn't have ruined it with a mod like that. Also, I doubt its doing 100 watts. Guy is blowing smoke up your ****.
make sure your antenna is properly tuned, and just use one antenna. it will work out better for ya.
you can't tune the radio. You must tune the antenna. I have a generic thread which explains everything you need to know about tuning your antenna. See here. Hope this helps you.
