The printer is stuck with message B200 , saying to contact canon service . It does not allow me to fax or anything else , I changed to new ink and the same message is always on the screen B200 - contact service tech .
Steps For Setup Canon MX712 Printer:
Step 1: Press the Menu button on your Canon PIXMA MX712 printer.
Step 2: Choose Settings and click OK.
Step 3: Select the settings of the device and click OK.
Step 4: Select the configuration of the LAN and click OK.
Step 5: Change the option wireless / wired and click OK.
Step 6: Select active Wireless LAN and click OK.
Step 7: Select configurations for the Wireless LAN and click the OK button.
Step 8: Choose the option to configure WPS and click the OK button.
Step 9: Now select the technique of the push button and click the button OK.
Step 10: Press the OK button on the device as the access point is prepared to work, then press the WPS button on the access point within two minutes.
Step 11: Once the device LCD displays the completion screen, press the OK button. You will be shown the LAN configuration screen.
Step 12: If the setup is not finished within two minutes, a timeout error will be displayed.
Step 13: Depending on the type of access point, the WPS button may have a different name.
https://www.canonprintersupport247.com/blog/how-to-setup-canon-mx712-printer
Try the following:
1. Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Place the print head back in and lock the lever down.
6. Place all of the ink tanks back in the printer.
7. Close the cover and turn the printer off.
8. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
SOURCE: canon powershot A430 says batteries need changing constantly
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
SOURCE: CANON IR2022I PRINTER
Do you have fax server?There could be problems with it.
Are you directly connected to tel. line with copier?
Try to recive faxex from different numbers and see wats going on
I had the same error, did the reset and only got another error, e04. I then removed and carefully cleaned the cartridges and the metal points in the printer that read them. The printer reset itself and worked fine afterwards.
