My car beeps when I enable and disable the alarm and I'd like to stop. It defaulted back to the beep when I replaced my battery and I'm not sure what sequence of events needs to happen in order to quiet it down.
SOURCE: strange beeping in my 2003 Alero
hey check the fues frist. then take a light tester aand see if you have power to your switch. . if every thing work out good it will be the switch
SOURCE: horn beeps as if in an alarm mode
It is shut down in an alarm. The owners manual says to unlock the passenger door to turn off the alarm and allow the engine to start. I had the same problem when I bought a 1996 Jetta whith a dead battery.
SOURCE: How do I disable the
If you lock your doors with the remote, you have to use the remote to unlock them or it set off the alarm. I don't know why the manufacturers designed it that way(kind of stupid)but it's programmed into the on board computer. You can't disable the alarm without creating a worse problem somewhere else.
SOURCE: pt cruiser disable alarm
battery of car is zapped of energy...not sure if alarm system to blame, after driving it for a few minutes..clock and radio display lights turn off, horn can barely be heard...sometimes, motor shuts down completely. have had to put in 2 new batteries in just a matter of 2 months?...any idea what this may be?
SOURCE: On a 2010 Nissan Altima 2.5s, how do I enable the
Welcome to Fixya
Try to trigger the alam of the car when its in armed mode. See if the horn will go off. Press the lock button twice. If you wont hear any sound coming out then the alarm's horn is the culprit.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
