Question about JVC Televison & Video
My tv screen is to dark how do I lighten the picture
Good picture on tv, but screen is so dark its light looking thru dark smoke
Posted by Jb Jeffers on
Lito Yara
    Habit-Forming:
    New Friend:
  • 32 Answers
If your TV has already fully adjusted in brightness set up?, and there will be no good picture results?...try to adjust the "SCREEN-Screw" at the flyback slowly. If the picture still dark'?. the picture tube has need to rejuvenate.
Posted on Oct 24, 2014
3 Related Answers
Derrick Buckles
  • 74 Answers
SOURCE: tv picture is too dark- worked with contrast and
This sounds like low screen voltage(A1)try adjusting the a1 voltage bottom control on flyback transformer if you have a voltmeter, voltage on crt base possible market screen or A1 shoud be beteen 350/500 volts when making adjustment remember to take into account current taken by meter If voaltage will not adjust flyback transformer will have to replaced
Posted on Mar 06, 2010
Anonymous
  • 443 Answers
SOURCE: well the picture lost light and it all looks
Try replaceing the projection lamp, or you may have a light engine failure. Good luck !
Posted on Jan 06, 2010
Testimonial: "good help, this guy knows whats up"
Anonymous
  • 9 Answers
SOURCE: tv is dark
looking on the back of ur tv near the cable input jack there might be an area where u can adjust the brightness on the flyback transformer. if there isn't you will have to remove the back of the tv and adjust it this way. PLEASE DO NOT TOUCH ANYTHING OTHER THAN THE BRIGHTNESS KNOB ON THE FLYBACK, CAUSE YOU MAY BE SHOCKED. so please be careful.
Posted on Aug 04, 2010
Do older tv's lose their color and sharpness 50" toshiba or is it the cable reception that is dark & grainy.
If we are speaking of a CRT, sure, a rear projection device, yes the bulb and mirror system picks of dirt, moisture, smoke, nicotine and the lot. If this is a new flat screen, yes the rear or back light system does lose its ability to produce a pleasant picture.
Good Luck
Mar 16, 2015 | Sharp Televison & Video
Dark picture screen/how do I fix it
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Oct 24, 2014 | Televison & Video
How do I get picture back on TV which was working the night before, which is hooked up to HD cable box, thru HDMI?
OS info is always helpful, if say you are running some type of nix, it's likely not getting recognized by xserver or if your running some version of windows your display manager has shut it down because of a resolution mismatch.
May 26, 2014 | Amstron Fujitsu LifeBook E390 Laptop DC...
TV powers on, picture blinks once, screen goes dark with green power light remaining on steadily
What is the brand name and model number to your TV? Provide more details, please. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 25, 2014 | Televison & Video
Picture too dark on lcd hisense
get to the screen menu and alter the contrast to lighten up the screen. take it back to the repairer as it may be only be replaceable-not repairable.
May 11, 2013 | LG 42LC2D 42 in. LCD HDTV
Dark picture..not bright picture
The whole point of a webcam is to be able to see the person you are speaking with, and let them see you. When the image broadcasted by your camera is too dark, the person on the viewing end won't see anything but shadows and dark shapes. Learn how to brighten your webcam image so the people you chat with can see you.
Place lamps behind and to the side of the webcam. This casts a light on your face, but the lamps will not wash out the image because they are behind the camera. Turn off lamps that are behind you. You have trouble seeing things when you are looking in the direction of the sun or a light bulb. Your webcam has the same problems. Don't make it stare at a bright light. Open up a white screen on your computer to brighten your face. The white screen will create the brightest possible light from you computer screen and help lighten your webcam image. This option is best when lamps are not available. Open up an empty tab in your Internet browser, or a blank Notepad document, and expand it to the full of your screen. Adjust your webcam settings. The settings available to you will depend on your webcam, but many of them offer a "Brightness" setting that you can increase to lighten your webcam. Open the program that came with your webcam, then look for a "Settings" or "Options" menu. Increase the "Brightness" setting until it has lightened your webcam enough.
b>
Feb 08, 2013 | Gear Head Computers & Internet
Best solution to improve picture quality. Screen
Try to turn the contrast down. It can really help out a lot. If this is not working look up your tv's best settings. CNET.com has some great settings under the forums.
If all else fails but a calibration dvd and go thru the settings. Some dreamworks and disney dvds even have them right under the disc extras. Hope I could help!
by the way, remember to cut some of the light in your room if it is well lit. It will help make the picture look better as your eyes can distiguse the light and darks better
Mar 16, 2010 | Mitsubishi WS-55311 55" Rear Projection...
Tv picture is too dark- worked with contrast and
Mar 06, 2010 | Televison & Video
Televison & Video Logo
856 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
