SOURCE: Heater Burner ignites but main blower motor will not turn on.
it sound like the blower motor may be seizing up. try spining the blade by hand to see if it feels free or not. the motor could be trying to turn but can then tripping itself out on overload. (most motors have built in safety overloads which will trip during an overcurrant event. aka too many amps.) you may have to replace blower motor
SOURCE: My mister heater big max
It sounds like your low voltage circuit is open. Here are things to look for that you should be able to find on your own
1) check for a tripped limit switch
SOURCE: The patio heater starts fine
First thing to check is the fuel, if running on butane it will on cold nights slow down, pop and then go out. It will then run again when it's be left for a while. Butane works best on warm nights but for all year use switch to propane, this will work to -6 degrees. For information on fuel see different types of fuel. If that does not not fix it try this help pages patio heater top repair tips.
SOURCE: heater wont stay lite
Needs a service, make sure there is no dust between the thermocouple and the pilot assembly. An air compressor should do it.
