Question about Brother Industries, Ltd DCP-7020 Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop Printer, Copier, Scanner - 20 ppm Mono Print - 2400 x 600 dpi Print - 20 cpm Mono Copy LCD - 600 dpi Optical Scan - 250 sheets Input - USB
How to replace paper feeding kit on DCP 7020
Paper jams every other time and beginning to continuously jam
Posted by Deby Mansfield on
Jay Plesset
  • Brother Indu... Master
  • 2,942 Answers
Most likely all you need is to clean the rubber feed rollers. Use alcohol.
Posted on Oct 24, 2014
Dcp 7020 paper jams
DCP 7020 PAPER JAMS SOLUTION1... LASER MOTAR DASTE CLEAN LASER MOTAR
Jan 16, 2013 | Brother DCP-7020 All-In-One Laser Printer
Paper jams in first rollers out of paper tray one sheet will feed but several will jam
Check for wear on the first set of rollers. If they seem fine and your print settings are correct (media type and size) then you may need to replace a small part in the paper tray. When I have seen this issue previously I needed to replace a seperation pad that lifts paper up(spring loaded to raise the paper the right amount as the paper level goes down) and has a rubber pad on top, when the rubber pad gets worn and it no longer 'holds' the bottom sheets that are not supposed to feed.You can get these from brother directly or from service centers/retailers. The part you need is the paper feeding kit, part no. LM6291001 and it looks like this!
Aug 22, 2011 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 Paper Jam, we keep having the paper jam at the paper exit at the top/back of machine. I've examined closely from front, back, bottom, even removing a few easily removed parts, but can...
This is caused by dirty exit roller. As this machine is a pain to dismantle I suggest that you try and clean these rollers ( 3 or 4 rubber small ) as they rotate. Opening and closing the front door will keep rotating them for you. Use a damp wrm water lint free cloth. I use a compound named Print Clean but metho can be used also.
May 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
Error 50 of Brother printer DCP-130C
Details of this error code are.
50,51,52,57,5A,5B,5C
5D,5E The machine does not work due to a paper jam or some sensor problem. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us".
May 01, 2011 | Brother DCP 130C All-In-One InkJet Printer
Dcp 7020 "Back Cover Open" lights up even after it
Try doing a power reset.
Turn off the printer/Unplug it for a few minutes/Plug it back in/Turn it back on.
Jan 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
MACHINE STOPS, SAYING IT A PAPER JAM.
I would try taking some cleaner such as fantastic or formula 409, remove the paper trays and clean the feed rolls then open covers and clean any rollers in the paper path.
You can also use rubbing alcohol, but a soapy cleaner tends to do better.
Jul 21, 2010 | Brother DCP-7020 Black and White Copier
Paper feed on my Konica 7020 is jamming can you help?
It depends on where it is jammng, if it is in the feed area change paper or clean the feed rollers above the paper tray. If it is crunching the paper look to see what is stopping it and correct it. If it still jams in the machine you need a tech to see why.
Mar 23, 2010 | Office Equipment & Supplies
DCP-7020
My suggestion is to take the printer to the highest floor in your building open a window and see if it can fly. or just use it as a $200 paper weight because after 3 months it has been to the shop 3 times and still is not working they way it should. Bad equipment bad support, and just plain bad product all around.
Mar 04, 2008 | Brother DCP-7020 All-In-One Laser Printer
Brother Industries, Ltd DCP-7020 Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop Printer, Copier, Scanner - 20 ppm Mono Print - 2400 x 600 dpi Print - 20 cpm Mono Copy LCD - 600 dpi Optical Scan - 250 sheets Input - USB Logo
279 people viewed this question
Top Brother Industries, Ltd Office Equipment & Supplies Experts
Marvin
Marvin
Are you a Brother Industries, Ltd Office Equipment and Supply Expert? Answer questions, earn points and help others
