Question about Robotoolz RT-7210-1G Self-Leveling, Remote-Controlled Green Beam Laser Leve
I need my Unit rebuilt, unit was knocked over and the bearings fell out.Can this be done?
Looking for a quote to rebuild a RT 7210-1.
Posted by Jude Kelly on
Donald Killgore
    New Friend:
Hey Jude Kelly, RE: your having broken your RT 7210-10 laser level - the ball bearings falling out almost certainly dooms your base unit; however, your transmitter may still be good. I am in need of a transmitter and if you wish to sell, please contact me at [email protected] Thanks.
Posted on Oct 26, 2017
brook_tno
    Scholar:
  • 90 Answers
Unfortunately no. Nothing you do will make this accurate again. These are throw away lasers.
Posted on Sep 05, 2015
1helpful
3answers
Rods are knocking,
To put it in layman's terms it means tat the big end bearings are shot and it will be new bearings and crank shaft grind which leads to engine rebuild which leads to lots of dollars. I do not consider it a stupid question at all as it is a common statement by "shade tree mechanics" looking to make a fast buck at your expense.. It is best if you have a series of tests done to determine the condition of the engine first. Find yourself an accredited ,reputable mechanic and have the following tests done.1--- have a compression test (dry then wet) done to determine the condition of the rings and bores. IT will also find if there are cracks and head gasket problems( minimum psi should be around 120psi). 2--- have the oil pressure tested with a mechanical gauge to find the working oil pressure ( minimum idle pressure around 20psi) reduce the engine idle to as slow as possible and listen to any knocks in the motor. Pull the plug lead of each cylinder in turn and if the knock subsides it can be worn gudgeon (wrist pins) pins in the pistons. When you have the results from all these tests you will have a good guide as to rebuild, replace with a reconditioned engine or get a good unit from the wreckers.
1helpful
My bmw rt 1150 starts fine but when revving up a knocking is present, what would be the cause
most likely spun a rod bearing if the oil ran low..the oil amount is very small and leaks are deadly for small engines..be looking for another engine if youre gonna keep the bike..sorry the truth hurts abit..mine was a 76 honda 200 and a 79 kawasaki .. traded the 750 for a flatbed trailer I used behind my suburban for years..
1helpful
2answers
Dropped rt7210-1 bearings out laser and drive ok
Dropped my robolaser RT7210-1 and the bearings came out.
88 mercury cougar slips in fourth and fifth gear what could cause this?
Worn bearings, worn plastic bushings in the linkages. Incorrect linkage adjustments. Usually there is clash and difficult shifting if the latter is the issue. The first two are most likely scenarios.
If it has been jumping out of gear for a while, rebuilding your transmission may be more expensive than buying a rebuilt unit outright or rebuilding a used unit.
How hard is it to rebuild or replace a slave cylinder on a 1987 Cavalcade, it is leaking someware inside no "puddles" and can you suggest a parts "house"
Clutch slave cylinder rebuilds require the removal of the "secondary" drive unit, the right angle drive unit beside/aft of the left drivers foot peg. While you are in there, you need to check/fit the "Tracy Plug" and check for play in the output bearing.
Parts and detailed instructions are available at www.cademaster.com and if you haven't already done so, join the worldwide yahoo email group with over 1400 members via www.suzukicavalcade.com and ask more questions about this task.
I have aknocking noise from a rebuilt engine on 04
Not a good thing. More than likely it's the rod or main bearings.
The oil pressure drops when stopped causing the check gauge light to come on.
Install an external mechanical (yours is electro-mechanical) oil pressure gauge on the engine and read actual oil pressure. If it is below 15psi at normal idle warm, (I like a reading of 30 or above on jeeps) then you will need to determine the reason. Causes can range from worn bearings to obstructed oil pump pickup screen. Any knocking inside the engine tells you there is a bearing problem...really doesn't matter which bearing it is, likely all are worn and will need replacement, or engine needs rebuild or replacement. I've been doing this a long time and have found that in-car bearing replacement, unless done very early on and "matching" bearings to existing clearances, will most times relieve the problem for a few days or weeks and therefore is pretty much a waste of time and $.
If mechanical gauge reads normally, likely the sending unit or the passage going to it is plugged or the unit itself is going bad.
1helpful
2answers
Can the bearing on the supercharger be changed sperate?
You can replace the nose with bearing. If its making a clunking sound you will need the whole unit. Check out some of the people that rebuild these for more info.
Robotoolz RT-7210-1G Self-Leveling, Remote-Controlled Green Beam Laser Leve Logo
Top Robotoolz Measuring Tools & Sensors Experts
ADMIN Canada
ADMIN Canada
ray gallant
 Mikey
Mikey
Are you a Robotoolz Measuring Tool and Sensor Expert? Answer questions, earn points and help others
