Question about Pioneer VSX-D608 Receiver
THE SPEAKERS FRONT LEFT AND RIGHT IS NOT WORKING ON DTS and 5.1
Overload
When using receiver in FM mode, I have sound on theses speakers but on DTS and 5.1 I don´t have sound on speakers front left and front right.
When the receiver is working on 5.1 and DTS with low sound (-20db) it works without sound on these speakers, but when I turn the sound level to -10 or highter, the receiver inform OVERLOAD and turn off automatically.
When testing Tone, I don´t have sound on speakers front left and front right.
Pls, help me to see what is the issue.
Posted by miltonesteve on
Anonymous
  • 4 Answers
Everytime I use the DTS functions to enable my surround sound, no sound goes to my speakers. I am able to use it only for the standard output with the left and right front speakers. What could be causing...
DTS should be enabled only if your source has a DTS digital audio out connected to the receiver.Mostly only DVD / Bluray players have DTS sound and is outputted through an optical or co-axial port on the back of the player. Its a multichannel digital encryption technology where the signal is sent through one cable and your receiver decodes it into 5.1 or 7.1 channels according to the source.
Apr 22, 2011 | Pioneer VSX-D810S Receiver
Weird surround sound speaker behavior with Denon 2105 7.1
Sounds interesting.
It may sound silly, but can you check all your speaker cables again and confirm whether they are connected to the right connections. please check all cables as also the severed one and please repair it also.
Now please go to the system-set-up and do an auto setup and set up your speakers. Listen to the test tones and confirm that they are coming out of the correct speaker.
Once these are set, then if still there is mismatch of sounds, then we could further trouble shoot.
Mar 08, 2009 | Denon AVR-2105 Receiver
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
I had this problem too. Finally, after using the MCACC setup and making sure all the speakers worked, I found I had to set the source to FM, TV or whatever from the remote control and set the mode to advanced surround sound using the front panal button on the upper right. Had to fool with them a lot. Good luck.
Jan 03, 2009 | Pioneer VSX-818V-K Receiver
STG DR510 no sound on left front channel
Can I assume the calibration procedure also didn't work for the Front left channel? (It's not a "surround" if it's in the front). Switch the receiver to Stereo mode to eliminate any DSP actions. Tune an FM station to eliminate any external device or cable issues. What do you hear from the two Front speakers?
OK? Select a DSP surround mode. Check all modes. What happens?
If the channel goes dead using some or all DSP modes there's probably something wrong with the processor. If they all work...
Isolate the source that exhibits the problem.
It was a bad left channel cable somewhere, wasn't it?
Dec 24, 2008 | Sony STR-DG510 Receiver
Rear Surround speakers
Best thing to do is to put the unit in 5 channel or 7 channel mode. That will send left ch information to the front left and rear left speakers ( both will get the same information). Ditto with the right channel. The center channel will get centre channel information.
If all the speakers work, go out and rent TOP GUN. ( yes its old), BUT there are a few extreme scenes , one of which is the elevator scene, where the camera changes perspective and suddenly you hear the elevator doors close BEHIND you through only the surround speakers ( have the unit in surround mode....NOT 5 or 7 ch mode ). If this works ok, then you have no problems.
Remember, surround sound only produces information in the rear channels when the information is there. To check out the digital and DTS decoders, get an action flick. If you can, get a remote too, because that will unlock many features about the receiver that you cant get to with the front panel controls. Also go to yamaha and download the owners manual ( its free !!).....that should get you going.....
best of luck...
Rob
Jun 08, 2008 | JVC RX-880V
Surround sound not working properly
Hi guys,
Make sure that your sound aka dvd or whatever is set for a DTS (5.1) set your dvd at bitstreem and your receiver to automatic detection. When your movie will start you will heard your Receiver Relay//Mosfet clicking and a Red led will say DTS once you get there you will be able to select your Doldy digital surround the real one.
Ps: if you want to reset your VR-309 to default HOLD the POWER button for 5 sec unplug it from the wall hold it for 5sec while unplugged and replug it will be rested to default.
Oct 27, 2007 | Kenwood VR-309
Not getting sound from right speaker
How do you have the audio hooked up from the TV set? If its s video or RCA plugs? If it is switch them around and see if it swaps channels that goes out . If it does then the output cable or the jack is bad. If your using an HDMI ir a scart cable. The cable or connections could be bad. Unplug it and reinsert it or while the units on mover it around and see if the audio comes back on.
Sep 22, 2006 | Yamaha RX-V550 Receiver
Pioneer VSX-D608 Receiver Logo
769 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
ThaMp3Doctor
ThaMp3Doctor
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
