Question about Sewing Machines
How do I attach a twin needle post to my Bernina 950
I have a Bernina 950 which I have been using in my dressmaking business for about 2 years. I recently purchased a twin needle post so I can neatly finish garments but I can't seem to get the single needle pos tout of the machine to install the twin needle post. How do I do it?
Posted by Erina Noble on
Sewingirl
    Sergeant:
  • Sewing Machines Expert
  • 248 Answers
Hello Erina
Sounds like you purchased and wish to use a twin needle which comes as two needles on a single needle shaft, correct? That is terrific and you have a wonderful machine.
Remove the needle in the machine just the same as you have been over the past 2 years. Unscrew the needle clamp screw, pull down on the needle or part of the needle in the machine and insert the new twin needle shaft into the needle bar. Tighten the needle clamp screw and thread the needles using two sources of thread on the top.
If the existing needle post is not coming out of the needle clamp easily, use a pair of pliers to grip and pull down. Cover the sewing surface to ensure that it will not be damaged as the pliers free the needle. If the needle is firmly embeded, you may need to give the pliers a gentle tap with a small hammer.
If using a zig zag stitch make sure that the width does not exceed the twin needle limit; otherwise as the needles swing from side to side they can hit the stitch plate and brake.
Happy Stitching
Posted on Nov 17, 2014
5 Related Answers
Peter Bradshaw
  • 106 Answers
SOURCE: bernina 1300 dc overlocker skipping stitches
Make sure the chain stitch thread is threaded exactly as it should be, make doubly sure the thread comes off the bobbin vertically and runs through all eyes smoothly. Any faults in the threading causes extra tension at the needle despite what the tension is set on.
If this is not the cause then the needle depth and the looper timing needs checking.
Rob
Posted on Mar 30, 2008
Anonymous
  • 3 Answers
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
Posted on May 22, 2008
Ruth Peck
  • 69 Answers
SOURCE: What foot do I use with the twin needle?
You need to use the zig zag or satin stitch presser foot with the twin needle. You also need to make sure you have the zig zag plate on your machine. Also, remember when using the twin needle, you cannot put your stitch width beyond half way. The best thing to do is once you select the width, turn the handwheel to see where the needle is going to hit, you want to make sure it clears the plate or it will break.
Posted on Feb 09, 2009
Tally Girl
Tally Girl
  • 1134 Answers
SOURCE: I couldn't find the Brother
most domestic sewing machines use 130/705h system needles - buy a pack each of size 70, 80, 90 and 100 to start. if you plan on sewing knits (stretchy) fabrics then buy a couple packs of ball points in size 70 and 80. put in a new needle for each garment you sew as a needle goes blunt in about 6 hours depending on what you are stitching. visit www.sewing.about.com and check out sewing machines 101 and debbie's article on sm needles for more good info. depending on what your heavier weight fabric is you may need to use a 110 size to handle it. the denser the fabric the bigger it needs to be.
Posted on May 17, 2011
Tally Girl
Tally Girl
  • 1134 Answers
SOURCE: do I use a twin needle with my narrow pintucking
if you want to sew pin tucks, then yes, you could use that foot providing the hole is large enough for the two needles to pass through. Twin needles come in 4mm gap and 2.2mm gap so just check that it will fit. When using a twin needle, there is a lot of heat created so it is always important so sew slowly, going too fast will cause the needles to break.
Also, you should check on the twin needle type, modern machines now using a twin which is slightly offset, the block colour is usually a dark brown/red colour. Your machine may have come with a twin needle in the needle selection so take a good look at it and see if it is an offset one, then make sure you buy replacements of the same type.
THe pin tucking foot allows you to keep rows of pintucks lined up, it will have grooves in the base that you can run the previously stitched pintuck through to keep even distances. Best on lightweight fabrics like cottons, lawns, batiste etc. You'd probably go for the narrow 2.2mm twin needle to get a nice fine tuck. I like to press each seam after stitching too to give a sharp tuck.
Posted on Nov 02, 2011
Can you use a twin needle on a Bernina 1000 Designer Sewing Machine, if so how do you thread the needles?
As far as I know, you can use a double needle on your Bermina. When you thread, be sure the presser foot is ALWAYS RAISED. Thread the first thread all the way through and then thread the second all the way through. If the tension disk has a divider for dual threads, be sure each thread goes to one side of the disk and the other to the other side.
Jun 01, 2018 | Bernina Sewing Machines
I don't know how to use the darning on my bernina 950. Can you advise
You need to use a darning presser foot--there are several designs of darning feet made by Bernina or generic brands (be sure the generic model has the appropriate attachment for your particular Bernina). You can find metal or plastic, clear or solid foot, open or closed toe, spring-loaded hopper or not, etc. Drop the feed dogs. If it is thinner fabric (lighter weight than denim), it sometimes helps to put the fabric in an embroidery hoop (upside down with the fabric next to the needle plate). If the hole is small, you can use the little hoop that should have been included in your Bernina accessory kit. Then you manually move the fabric back & forth, up & down under the presser foot while stitching.
12 BERNINA presser feet Darning foot 9
How to Use the Big Foot Darning Quilting Embroidery
Choose Your Darning Foot Quilting Foot and Learn to Machine Quilt
Aug 08, 2017 | Bernina Sewing Machines
I just need instructions to thread a Bernina Virtuosa 160 for pintucking
Your owner's manual should have instructions for using a twin needle.
Most machines can use a twin needle. However, some machines have two tension disks so one can separate the two threads and get equal tension. (The Bernina 930 has two tension disks, so am assuming your newer machine does also.) Look at the top of your machine where the tension mechanism resides and see if there is a right and left side. In either case, do NOT thread both threads at the same time as the threads can become twisted. When threading the machine, ALWAYS RAISE the presser foot, thread one thread completely. If threading the left side of the tension disk, also thread the left needle. Then thread the second thread, making sure to use the other side of the tension disk and needle.
Just a reminder to be careful using any zig-zag or decorative stitches since a twin needle requires a narrower stitch width to avoid broken needles.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0ahUKEwiawf-507_RAhVHwlQKHQrnAXgQFgg4MAQ&url=http%3A%2F%2Fwww.itsastitchonline.com%2Fmastery_on_the_web%2Fmastery_153qe_163_1-4-02.pdf&usg=AFQjCNHHww3jbxbLXZYNj6vuCZE4-kVa8g&cad=rja
Stitching Odyssey How to use your twin needle
How to use twin needle So Sew Easy
Bernina Instruction Manuals
Jan 13, 2017 | Bernina Sewing Machines
Threading for twin needle how to thread artista 180 bernina
Hi you should have a plastic piece in your tool kit that holds the second spool of thread. It clips on behind the existing thread stand
then thread as normal with one thread on each side of the top tensions now continue to thread down to the twin needle.
the resultant look will be two straight lines on top and a zig zag look on the bottom
hope that helps
wayne buss
[email protected]
Mar 12, 2015 | Bernina Artista 180
How do I adjust the hook needle timing on my bernina 950?
I have a Bernina 950 sewing machine and I had a thread jam, and to remove the jam the hook came apart. Does it mean every time I have a thread jam I have to pay someone to fix the hook?
Why can I do this my self if someone will share pictures or knowledge?
Feb 28, 2015 | Bernina Sewing Machines
Can you use twin needles on bernina 1080
I have a Bernina 930 Record that will take twin (even triple) needles, so I don't know why your 1080 wouldn't. Just be sure your machine does not have the straight stitch plate on it, that your presser foot can accommodate zig-zag stitch, and that you carefully adjust any zig-zag stitch width so the needles do not hit the presser foot or stitch plate. I'd suggest installing the double needle and then carefully hand rotate the handwheel to see if the needles will hit anything. If you can make a full rotation of the handwheel without anything hitting, then slowly try it with the motor engaged.
Feb 23, 2015 | Bernina Sewing Machines
How to twin needle sew with bernina 930
The manual should show how to use a twin needle. You can download a manual here:
BERNINA Support Machine and Accessories Finders and Software Support...
Jul 07, 2012 | Bernina Sewing Machines
My Bernina 180 will not feed when I use a twin needle on knit fabric.
are you using a stretch twin needle; without one you'll get skipped stitches. However, the feed sounds more like a feed dog issue. Have you lowered the feed dogs for any reason? Will it sew on a woven cotton okay? If yes, but not feeding the knit then you could try turning up the presser foot pressure and see if that helps with the feed.
If you look across the needle plate with the presser foot removed and manually turn it through a stitch sequence, can you see the feed dogs coming up above the needle plate??
Jun 13, 2011 | Bernina Artista 180
Bernina 1630 needle will not move go side to side.
If you can pull the needle bar down manually and it springs back up, the basting clutch is stuck. By someone who knows how, it's a very easy fix. I would guide you here, but I don't know how to explain it. Plus, you have to be very careful not to damage the spring loaded clutch.
Jan 02, 2010 | Tacsew 950
Bernina Virtuosa 150 and uneven layers or bulk.
Hi, have you tried changing the pressure of the presser foot using the dial on the side of the machine? Fiona
Apr 11, 2008 | Bernina Virtuosa 150
Sewing Machines Logo
312 people viewed this question
Top Sewing Machines Experts
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
