Question about Kodak EasyShare Cameras
What can I do to fix the screen? It is white when I turn it on.
I have it taken apart right now to see if it needed to be cleaned.
Posted by lily pierson on
wings_it
    Scholar:
  • 141 Answers
White screen on a camera is similar the blue screen of deat*@#$ on a computer. Faulty hardware. Check the wiring from the screen, but can't give you much hope sorry...
Posted on Nov 30, 2014
How do I clean or fix sticky keys (keys that take a lot of pressure to depress).
Most keyboards can be taken apart easily and cleaned with alcohol. remove the screws from rear of keyboard and it will come apart being careful with the keys not falling all over. if its a laptop they are difficult to clean because you cant take the board apart. you can remove keys and clean with Q-tip.
Feb 11, 2016 | Apple Usb White Keyboard A1048 - Spanish
I purchased a new screen for my laptop with the exact part number as the OEM screen after the original was broken. I hooked it up and when I power up the laptop all I get is a white lit up screen, no...
Welcome to Fixya. May i know the reason why did you change the screen? Is it the same issue that you have a white screen or no picture? Please provide the information needed to be able to fix the issue.
Thanks
May 22, 2011 | Computers & Internet
When I turn my camera on there's just a white screen and no matter what I press the white screen stays
The lcd has either gone bad or has worked its way loose some how. The camera needs to be taken apart and have the lcd ribbon examined. Try this first, it should be a ribbon with a clip, if this is in place the lcd is bad and needs to be replaced, look at ebay or amazon for a replacement LCD for your camera make and model, most are around $20 and easy to replace.
May 05, 2011 | Cameras
Pull-out spray is clogged. can it be taken apart and cleaned?
Obstruction may be in the screen, try unscrewing where the water comes out.
Mar 05, 2011 | American Standard 4205.100.208 Reliant+...
My roomba won't go forward; it just rotates right ~90 degrees and then left ~90 degrees. I've cleaned the brushes, taken it apart and cleaned the brush gears, popped off the front wheel and cleaned the...
Hi. You will need to replace the old/damaged IR LEDs in the front bumpers optical. If you are comfortable using a soldering iron, I can supply you the parts needed.
Sep 19, 2010 | iRobot Roomba 550 Vacuum
Ds lite screen flash white tehm off
The screen that does NOT flash will need replacing.
It may look fine and dandy but there is still an issue.
The reason for the flash is that when switched on the DS lite performs a qucik check of the screens, if there is an issue the unit will switch itself off again.
My answer is, judging that you have said you have taken it apart to have a look that you are willing to repair it yourself.
Have a look on ebay for the relevant screen (plenty of people on ebay stock them) and then replace the screen that does NOT flash.
This should solve your issue.
If you need a guide to replace the respective screen click on my name to access my profile and at the bottom of the page you will find my guides.
Hope this helps,
Regards,
SOD69
May 14, 2010 | Nintendo DS Lite Console
TV worked fine one night, next day screen is white.
The LCD Panel failed. There is no easy fix but try to get the T-Con board to fix the issue. However, this part is usually only available with the whole LCD Panel. This is usually the most expensive part in the TV and the whole TV needs to be taken apart to replace the panel.
Might be economically viable if you can find a place that carrys the T-con but Dynex parts are usually hard to find. The LCD Panel part alone will exceed the cost of the TV.
Oct 07, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
White vertical line
That is either a faulty ribbon cable to LCD display, or a defective lcd display itself.
In both cases tha computer must be taken apart and part replaced to fix the fault.
Parts are commonly found on Ebay, or can be ordered from toshiba.
Oct 10, 2008 | Toshiba Satellite A135-S4527 Notebook
Samsung d500 screen not working
Hija!!
I have the same problem! (white screen)
And I've red some forum topics, and found the medicine of this. If you take off the battery and whack it to a table or just with your fingers (little bit hard) on the battery side of the telephone, and after it, you switch it on, it will works!!! It works with my phone, but i think?it's just a temporarly solution! flex cable change is the really good choice i think!
so jhust bang your mobiles back some times, and see, that it works. Belive me!:)
Hi, Johi!
Mar 15, 2008 | Samsung SGH-D500 Cellular Phone
Cameras Logo
73 people viewed this question
Top Kodak Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
