Question about RCA Autoshot Cc4352 3 Inch Lcd Color Screen W/ Chargercarrying Case
Where can I buy a battery charger for my rca autoshot
Battery charger, where can I get one
Posted by Donna Patnode on
Mrs Featherbottom
    Sergeant:
  • 288 Answers
Easy, type in the name in a search engine and you can find it that way
I’m happy to assist further over the phone at https://www.6ya.com/expert/josh_8f8ad0a8f7e0e6d3
Posted on Oct 22, 2014
Battery was low. connected it to charger. comes on and off but apparently not charging. While on charger it flashes on and off.
Try a different plug, If not i would consider buying a new charger. If that does not fix it you need Tablet help
Mar 14, 2015 | RCA 8" Android Tablet w/Dual Tuner
NOTHING BUT A BATTERY AND RCA TABLET COMES ON WITH CHARGER BUT SHOWS NOTHING BUT A BATTERY ON SCREEN RCA 7 INCH TABLET
With the charger hooked up and plugged in the tablet will only show the battery on the screen briefly to let you know it's charging. It won't actually boot up until it has a sufficient charge. Just let it set that way for a couple of hours then try to power up.
Feb 26, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
Rca tablet wont charge
We are having the same problem with all 3 of our RCA tablets. Like you said, we have to find the right position for the charger and hold it that way. If you can hold it for a couple of minuets, the battery icon will flash and you will be able to tell if it's charging. Very frustrating I know. We will never buy RCA again. They are honestly junk.
Dec 27, 2013 | Televison & Video
Yea mine wont charge right i put the charger on it the green thing wont charge up so do i have to buy a new charger or what? please and thank you
U plug in the a/c power charger for the portable DVD player have power and work?Yes,than the litium battery is dead.Take out of the a/c charger like 4 or 6 hrs later dvd player have any battery power at all?No?Tries websites like Amazon.com,Ebay.com to buy a new litium battery or a compatible one for the replacement.
Feb 26, 2011 | RCA DRC6309 9 in. Portable DVD Player with...
GOT A AUTOSHOT 200X CC6363 THAT EVERY TIME YOU TURN IT ON GET ERROR CODE E04 & WHAT DOES IT MEAN
E04 - Battery in Safeguard mode.
The most common problem with this kind of model. there actually no fix for this problem. Unless of course your a jvc technician and can manage to open and clean all the sensor inside.
Have you tried to most popular solution for that.. tapping a little bit on the side of that camera. lol.
Look closely with the memory card, make sure it is inserted properly. push it a little more.
You may need to remove the battery from the battery pack and then reinsert again before turning it on. Doing it a few times may help solve the problem.
I do suggest you remove the battery when not in use. Leaving the battery inside is the usual cause for having the E04 when turning it on.
Hope this helps.
Mace1Mace
Dec 25, 2010 | RCA Video Cameras
CAN I CHARGE IT ON THE COMPUTER?
This device does not have that capability. Your cheapest solution would be to buy a battery charger and some rechargeable batteries. WalMart has one for under $10 that includes charger with two AA's and two AAA's included. This way you could be charging one while using the other of the AAA's.
Feb 03, 2009 | RCA TH1611 MP3 Player
Need the battery
Have you tried Batteries Plus near you or go online to www.batteriesplus.com
they list both the batteries and the chargers for this model of camcorder
Nov 18, 2008 | RCA CC6254 VHS-C Analog Camcorder
Need unit to put tape into, to play in vcr
What you need is a VHS C adaptor. I did a Google search and found at least 10 sites selling them. Rather than cut and paste, I suggest you go to Google and type in "VHS C Adaptor".
Oct 29, 2008 | RCA CC6263 Camcorder
RCA Autoshot Cc4352 3 Inch Lcd Color Screen W/ Chargercarrying Case Logo
Top RCA Video Cameras Experts
Lawrence Oravetz
ADMIN Canada
ADMIN Canada
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
