Question about Kitchen Ranges
Our gas oven has not worked in over a year. The electric panel was malfunctioning. The burners work fine. We just had some work done and had to turn off the radiators and manually fill the boiler an
Our gas oven has not worked in over a year. The electric panel was malfunctioning. The burners work fine. We just had some work done and had to turn off the radiators and manually fill the boiler and bleed the radiators. We turned the heat on this morning and suddenly, there's a loud humming in the gas line to the stove, and the electric panel works and allows us to light the oven. But what is the humming in the gas line? Why does gas to the heating system cause a humming sound in the gas line to the stove? And why does the oven suddenly work now?! Lol
Posted by Tierney D on
Gerald Griffin
  • 248 Answers
The hum may be a b ad regulator in the stove. Pull stove out and see if regulator is humming. It's where the gas line connects to stove.
Maybe the power was interupted to the stove which may have reset power to control board.
Posted on Oct 27, 2014
5 Related Answers
Anonymous
SOURCE: Kenmore Elite Electric Convection Oven Not Working
The control panel of Kenmore oven doesn't work. I bought it just one month ago. What should I do?
Posted on Sep 14, 2008
jumptrout51
steve
  • 3361 Answers
SOURCE: Oven won't turn on, but the stove is fine!
Replace the oven glow bar ignitor.
Posted on Apr 20, 2009
xenophanes
  • 42 Answers
SOURCE: Gas stove works, but oven does not
A gas oven will have some built in safety devices. Assuming that you have an electric pilot light sparking device, anything in the pilot light circuit could cause your problem
The oven does not "want" to turn the gas on unless there is an operating pilot system.
Since you never smell gas, but gas is available, then something in the pilot light circuit sounds like the culprit.
It could be as simple as carbon build up on the igniter or an internal fusing mechanism.
If you can get into the oven to the igniter, you could try cleaning the unit with a plastic scrunge.
I'm going to guess that this is not going to respond well to 'home grown' measures and that it will require replacement of parts.
Perhaps it is time to bite the bullet and call in repair......
good luck
Posted on May 20, 2009
Anonymous
  • 582 Answers
SOURCE: The top burners all work fine. When I turn on the
IF THIS IS A NEW STOVE THERE IS A VALVE IF YOU PULL OUT THE LOWER DRAWER AND LOOK WITH A FLASH LIGHT YOU WILL SEE A VALVE AT THE REAR OF THE STOVEAT THE LOWER LEFT OF THE VALVE THERE IS A TINY LITTLE HANDLE WHICH OPENS THE GAS TO THE OVEN FLIP THE LITTLE LEVER SO IT IS IN THE OPEN POSSITION, THERE ARE NO MARKS SAYING OPEN OR CLOSED AND THE LEVER IS VERY HARD TO SEE
TRY THIS AND SEE IF THE OVEN STARTS WORKING
Posted on Aug 25, 2009
Anonymous
SOURCE: Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Posted on Sep 13, 2010
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Bottom oven is not working - I set it but it isn't heating at all. There are no errors being issued, no gas odor. The top oven is working fine
Hi, open oven door, remove last panel, you will see oven burner, check pilot, if you see a small tube, manually strick a match and light it, then turn oven knob to on position, but if there's no pilot tube, then you got electrical ignition, could be faulty thermostat(knob you turn to put oven on) or thermocouple(device where oven burner conected too) could be faulty. but first check your oven pilot, it should be always lighting, sometimes, they get blown out. good luck.
1helpful
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
1helpful
GE Profile Gas Range oven turns off
I just read that the electronic panel malfunctions due to rear burner use. Now, I know that mine gets REALLY HOT in between the back burners (where the heat exhaust for the oven is) whenever I bake/broil. I am guessing that it can cause the same malfunction fromt he oven, as with the backburners. Whenever I use both back burners, mine shows F7 E6, too. Unplugging it for the night or just waiting til the beeping stops and then clearing it works... until I cook again. I read that the replacement part for the control panel is about $300 and another $200, more or less, to install it! I think this is more like a recall or manufacturer's problem. I have read plenty of complaints and I think GE needs to make a call to fix them!!
2answers
Check the voltage at the wall Sounds like you have lost one 120 voltage side Red to white should read 110-120 black to white should read 110-120 red to black should red 220-240 check at range and at the wall hope this helps
Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
2helpful
2answers
Oven burner doesn't light
If memory serves me,there are a couple of screws on oven floor.Remove panel.Sounds like ignitor is the culprit.It feeds back to control.It may glow and light but unless it is sending full signal,gas valve will not open fully and oven will take forever to heat.
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
