Possible selector problem when you push forward for 1st your are actually pushing into 3rd, try starting car from 2nd gear and see if it stalls as that would mean you are hitting 4th. usually a car can pull off in second gear ok. if this is the case go to a dealer to sort this out. as your gear selector is not aligning up correctly. if this is not the case the engine could be losing compression but that seems less likely.
SOURCE: Car runs fine at idle but wants to surge
there is a fuel pump inside the tank that is bad replace it
SOURCE: Car won't go into gear properly
it could be a few things bent shifting fork or first gear is out reverse runs off an idler that is conected to first gear.
SOURCE: Nissan Sentra 2005 automatic. gear shift from 1st to 2nd
drain and fill trans with fresh fluid
trans may have to be rebuilt
sorry
SOURCE: transmission is not shifting properly on my 2000
You could have a bad valvebody in your transmission or a bad pump in your transmission or your clutches are bad. In any case you have a bad transmission. Please rate my answer.
