Turkey Fryer is deep enough to fry a 12 to 14 pound turkey and wide enough to be used as a seafood boiler. Heating element is made of stainless steel. It comes with aluminum bailing basket with adjustable quick drain system, control with safety shut-off and a built in digital control with thermostat and timer. Swing out drain valve for easy draining and clean up. CSA certified.
Deep enough to fry a 12 to 14 pound turkey and wide enough to use as a seafood boiler, the Cajun Injector's Electric Turkey Fryer provides home fried cooking without the mess and hassle of stove top or outdoor methods. Equipped with a 30Qt. aluminum bailing-basket, you can submerge and fry a whole turkey or any other foods you'd like to cook fully covered. When the food is finished cooking, simply lift the basket up with the hanger hook, and allow it to drain over the pan with the adjustable quick drain system. A swing-out drain valve to empties the used oil when its time for clean up and a built-in digital control with a thermostat and timer ensures that the food cooks exactly as you intended. The CSA certified fryer features a clear lid so that you can check on the food without risk of burning and is equipped with a stainless steel heating element for long lasting quality.
SOURCE: Instruction manual for New Braunfels Turkey Fryer
http://www.charbroil.com/Consumer/KnowledgeBase.aspx
This is the web site for a company that owned the New Braunfels Turkey Fryer. Look at the info and videos for the 'Big Easy' and the instructions are roughly the same.
SOURCE: need manual
so there are a few different ditigal turkey fryers so go to http://www.masterbuilt.com/manuals.aspx and look for your model. good luck happy cooking
SOURCE: I have a 28 quart aluminum turkey fryer. can I fry
hello. yes, in fact it can handle a 30 pound turkey! Joe
SOURCE: need to dwnload ,manuel? For
Masterbuilt manual list
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Can't light Lodge Outfitters turkey fryer
Turn the timer knob to on. there should be a plunger type button on the botom of the timer. H old this in while pressing the igniter.Continue to hold plunger in for about 10 seconds after the burner lites. If you hear the flame go out , relight and hold a little longer. The timer knob will shut off after about 20 minuites
