Chemical Earthing Electrodes help in meeting all kinds of earthing and grounding needs for industrial and residential purposes.
Gmax Chemical Earthing Electrode consists of the main earth electrode encapsulated within another pipe filled with highly conductive compound. gmax main earth electrode thus protected by the presence of the conductive compound and the outer pipe last beyond a normal GI pipe electrode. Highly conductive property of the compound facilitates the fault current to immediately discharge through the outer pipe to the surrounding area.
Gmax whole assembly of the
Chemical Earthing Electrode is then installed in a bore made in the earth and the space around is filled by scientifically developed earth enhancing compound.
With an increase proportion of technology, we are manufacturing and supplying
Chemical Earthing Electrode.
Specifications:
Lengths
OD ISI GI
ISI GI Pipe
Technical Details
Outer Pipe Thickness
Inner Pipe Thickness
Outer
Inner
Copper Terminal
3.0 meter
300 cm x 90 mm
40 mm
50 mm x 6 mm
14 gauge
12 gauge
2.0 meter
200 cm x 90 mm
40 mm
50 mm x 6 mm
14 gauge
12 gauge
1.5 meter
150 cm x 90 mm
40 mm
50 mm x 6 mm
14 gauge
12 gauge
1.0 meter
100 cm x 50 mm
25 mm
25 mm x 3 mm
14 gauge
12 gauge
GMAX
Chemical Gel Earthing Electrode: GMAX Leveraging on our years of industry experience, we are instrumental in manufacturing and supplying Chemical Gel Earthing Electrode. Offered electrode is used for earthing owing to its excellent electric conductivity and durability. We used only quality-approved raw materials to manufacture these electrodes so as to make these suitable for use in commercial or residential areas. We properly check offered
Chemical Gel Earthing Electrode on different quality parameters to remove any kind of defect.
Product Attributes:
- Highly reliable for safety of human life
- High load carrying capacity
- Maintain low resistance value
- Maintenance free and corrosion free
- Available in different specifications
- Easy installation and longer service life
- Low thermal insulation and high conductivity
- Protect from voltage breakdown or leakage current
