Question about Kitchen Appliances - Others
Hi my double barrel slush puppie machine keeps freezing up and stops it from turning and mixing suction . Have trted all the temp setting . Thd solution is mixed right
Posted by Julie on
jasbo
  • 2,239 Answers
The machine freezes and stops based on the thickness of the slush. if it's mixed right, the problem is the torque switch next to the motor (if it's a cab or a ugo machine) or the torque sensor (for torque sensor models)
Posted on Nov 30, 2014
1 Related Answer
projdoc
jasbo
  • 2239 Answers
SOURCE: I have an Ultra 2 bunn slush machine. One hopper
make sure it's mixed properly. if there is toomuch water, it'll freeze solid. if the mix is too rich, ice will form on the outside of the bowls. you may also have a low refrigerant level.
Posted on Feb 13, 2011
Faby 3 slush machine over freezing
Assuming the mix is mixed correctly and the auger is turning, make sure the micro switch to the right of the motor in the back is in place correctly and works ok. That switch tells the freezing to stop.
Jun 13, 2015 | Faby Cab S.p.a Faby CAB Frozen Drink...
Why does my ugolini slush machine over freeze only on one side?
check your mix. if it's too lean (not enough syrup base), it'll freeze too quickly. if the auger stops moving when it's freezing, you blew a gear and it won't know when to stop freezing. also if the torque spring on the right side of the motor (through the back) is broken or missing, same thing.
Jun 27, 2014 | Kitchen Appliances - Others
Clean mould
take it apart. you should have a picture manual on the left side of the machine to show you how to clean it. if it's a later model, it won't have that. take the bowls off, the auger off, and clean each part; especially the auger seal (looks like a suction cup). lube the seal and the rear bowl seals (large white silicone rings in the back) and reassemble. mix a 1/2 teaspoon of bleach in 5 gallons of luke warm water and pour into the bows equally. turn on stir but not freeze for 2 minutes. no need to rinse, the bleach is too diluted. drain and fill
Apr 29, 2014 | Bunn Kitchen Appliances - Others
I make alcoholic slushys with my Bunn 2 double hoppers. I have 4 machines. 1 works great. 1 freezes well but gets a huge amount of ice build-up on the outside, and the other freezes but thaws out a
the ice buildup is from the brix level being too high. the mix is too rich to freeze fast. it freezes based on torque, not temp, so it'll just keep getting colder and colder until it's thick enough. once it gets below 24 degrees, the condensation on the outside will freeze. the other, check the defrost time.
Apr 22, 2014 | Kitchen Appliances - Others
Ugolini slush machines
you need to replace the gear bushings in the auger motors. or if they're no too bad, you can just flip them and get more time
Apr 06, 2014 | Kitchen Appliances - Others
My faby slush machine is freezing up
mix too lean. add a bit more base. also check the torque switch next to the stir motor. if it's stuck open, it won't stop freezing
Apr 02, 2014 | Faby Cab S.p.a Faby CAB Frozen Drink...
I have a 2 hopper bunn ultra 2, both sides are icing over on the outside
the mix is too rich. add some water to each side. it freezes based on torque, not temp.
Aug 17, 2013 | Bunn Margarita Machine Ultra 2 Slush...
Hoppers freezing up on outside
first, make sure you are mixing the product properly. if it's mixed too rich (not enough water), the temp will keep dropping until it's thick enough, thus freezing the condensation on the outside. if that's ok, go into the menu (holding down the "gourmet" button) and put on a defrost cycle; off at a certain time, back on at another. should defrost for at least 8 hours
Aug 17, 2013 | Bunn ULTRA-2, 120V BLK HP
I have a 2 hopper bunn slush machine.One hopper freezes the second one does not
May 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
Kitchen Appliances - Others Logo
1,766 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
