Question about Nordic Track NordicTrack C2050 Treadmill Walking Belt
I have a NordicTrack C2050. The belt abruptly stopped moving. I can hear the motor running but nothing is moving. I have had this machine for several years with no problems. Your thoughts are grea
I have a NordicTrack C2050. The belt abruptly stopped moving. I can hear the motor running but nothing is moving. I have had this machine for several years with no problems. Your thoughts are greatly appreciated. I miss the treadmill!
Posted by Linda Ekstrom on
Thomas Smithbrother
    Top Expert:
  • 3,698 Answers
Check bewlt for bad bearings/dirt in bearings etc. replace drive belt.
Posted on Oct 21, 2014
3 Related Answers
Anonymous
  • 40 Answers
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Posted on Nov 01, 2009
Joshua
  • 95 Answers
SOURCE: Nordictrack C2050, belt was slipping and I got the
I am not an expert on what you may need to order but I do want to give you a link in case that may be helpful... FitnessRepairParts.com has parts lists for several versions of the C2050... look for a decal or label on the machine to get the exact model number, then click on that model and look in the list for 'Roller, Front' or 'Roller, Rear' or 'Treadbelt.' Hope that helps.
Also if you need someone to come look at it you can find a list of servicers near you here
Posted on Feb 17, 2011
How do I fix a NordicTrack C2050 treadmill that has abruptly stopped?
see if you can remove the motor hood and look at the drive belt. it is a little belt from the motor to the front pulley to turn the walking belt. its either broke or fell off
Oct 21, 2014 | Nordic Track Nordictrack C2050 Treadmill...
Error codes 660 & 595, all functions perform, new motor from Icon, but motor will not go
please test the output voltage from control board motor, for voltage measure in terminal motor, if there are NOT voltage in output the control board is faulty.
2) Test if there are voltage terminal motor, if there are the motor need to be test. Loose the belt and try again. and if the motor RUn YOU need to LUBE the deck belt board.
Oct 15, 2013 | Nordic Track Nordictrack C2050 Treadmill...
Error code 660 & 595
test the output control board motor, if there are NOT voltage for to input voltage terminal motor, the control board is faulty, replace.
2) If there are voltage terminal motor, the motor need to test, take out the belt, and try again if the motor RUN the problem is deck belt board, LubE IT. see my personal TIPS for motor.
Treadmill belt stops abruptly
This happen because the lack of LUBE in the machine according with the instruction maintenance.
Please see the video and proceed according , LUBE the rollers bearing too.
God bless you
Jan 07, 2013 | Nordic Track Nordictrack A2350 Treadmill...
C2050 belt does not turn
LUBE THE deck belt inmediattely, maybe you have WORN deck belt
2) LUBE the rollers bearing too
3) test the drive belt motor for worn, replace or adjust it
4) test the input voltage motor, if there are the motor need repair, See my personal TIPS.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 24, 2012 | Nordic Track Nordictrack C2050 Treadmill...
My exp1000 stops abruptly...if you are not holding on, you could topple off...help
this happen because lack of maintenance schedule.
LUBE inmediately the DECK BELT, the machine Stop, BECAUSE has a protection system for electronic component.Maybe you have a worn DECK BELT, time to change it.
2) LUBE THE rollers bearing too.
3) Measure the input voltage motor, if there are the motor need repair. see my personal TIPS.
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the b.diagram + video and proceed
God bless you
Oct 12, 2012 | Nordic Track NordicTrack Treadmill, A2550
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
While using my Nordictrack a2550 this morning, the walking belt began to slip very badly. I checked the alignment and adjusted the tension of the belt as per the user's manual but the belt stills slip...
if it really is the walking belt that is slipping keep tightening the adjustment screws till the belt will not slip when you try to stop it ( set speed to about 3 and then with your foot try to stop belt from spinning - you should be able to make the motor and whole machine come to a stop ) make sure it is really walk belt spinning and it isnt the motor belt slipping. (if it is motor belt slipping when you try to do the stop the belt trick i just described you will see the walk belt and front roller stop but still hear the motor turning) once you get walk belt tight enough so it doesnt slip then you can worry about keeping the belt centered.
let me know if you need more help on this and let me know how the stop the belt test went
good luck!
Mar 25, 2011 | Nordic Track NordicTrack A2550 PRO...
Nordictrack C2050, belt was slipping and I got the cover off. and black stuff is all around the belt moving the roller that moves the treadmill. When I walk on it the belt would shuffle and sometimes the...
Feb 17, 2011 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack C2050 Treadmill Walking Belt Logo
311 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
Jesse Garza
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
