None of the buttons e.g menu, function set,time,display photo pictures taken and more
If you need help with a Canon Powershot, email this site: www.CamerasAndParts.com I don't have their email address handy but it should be on their site. They only deal with the Canon Powershots are they are excellent for help with these cameras. If you need to have it serviced, they're the place for these. They are not much at all as far as cost for having a Canon repaired and they do excellent work. They're also about the fastest on the turnaround times too. Hopefully they can help you with this one. Good luck
It's possible that your camera is like my Canon 20D and 5D cameras. If so, the power switch on the back of the camera is a three position switch. Make sure you try each of the two "ON" positions as one will give full access to available buttons while the other will restrict the use of many of the buttons. Good luck
SOURCE: Blank LCD screen
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
SOURCE: Canon Powershot SD 1100ES - display problems
My mother has this model camera. I believe there is a setting in the main menu that will allow an energy saving mode that sets the display time or no display. If not it's under warranty and your retailer should replace it if it is within 30 days of purcase date.
I hope this helps, goood luck!
SOURCE: Date/time stamp control in Menu won't allow access
In many cameras these settings depend on the shooting mode. Did you change the shooting mode? If so, return to your normal shooting mode and the function should be available again.
If this doesn't fix your problem I need to know if you have your camera's user manual. If I can find the solution in your user manual I need to know if you can read the steps in your own manual or if I need to provide you a link to read the manual online.
SOURCE: Canon PowerShot G2 buttons don't work
You have a bad button board . This is a single board with a series of small button switches that control all these functions. Most repair shop will charge around 75.00 to fix.
SOURCE: Self timer Problem with Canon Powershot Sx 110 IS
Have you tried NOT setting the shots to 3.
