2005 Hyundai Tucson Logo
A
Anonymous Posted on Oct 20, 2014
I have a 2005 Hyundai Tuscon. The air bag light is on, for a long time. What do I do? Is it under the air bag recall"
Again--air bag light is on on dash board. Is it part of air bag recall?
carlos falero
Level 3:
Genius:
  • Hyundai Master 1,327 Answers
  • Posted on Oct 21, 2014
 carlos falero
Hyundai Master
Level 3:
Genius:
Answers
1327
Questions
Helped
349197
Points
2968
Posible they cover unde recal this truck have two recalls for the air bag system you need to find the phone number of hyundai customer supor and you geve the vin number and they goin to tell you if is under recal you truck
5 Related Answers
Anonymous
  • 304 Answers
  • Posted on Jul 30, 2008
SOURCE: Auto AC leaking water
There is a drip pan to catch the water that drips from the condenser on the AC unit. Take the vehicle back to the shop and make them repair it. They are responsible for this repair as they broke or dislodged it when they replaced the airbag. Refuse to pay for this repair because they caused the problem. If they give you a problem contact me with their number and your info and I will make them stand behind their work or I will make a full scathing report to the better business people and they don't want that. Let me know how you make out
George
Anonymous
  • 3 Answers
  • Posted on Feb 09, 2009
SOURCE: dash lights
To my knowledge only a lexus dealership can correct the air bag light, also it seems that with the older lexus models that dash lighting is a common issue. I would suggest checking your fuses for loose or burnt out ones, as well as checking for loose wiring in the dash unit itself which a mechanic should be able to diagnose. not sure if that helps at all.
Anonymous
  • 69 Answers
  • Posted on May 27, 2009
SOURCE: Air bag light won't go off
There is a chronic problem with these models. If you have or had something under the seat, it may have knocked the wiring harness connector loose. Hyundai has not issued a recall on this, so your dealer may or may not charge you for the repair. I would attempt to reconnect the wire harness yourself. It is just two plastic pieces that slide together. You may want to use electrical tape or something similar to hold it together to prevent further problems, as they don't hold as securely as they should. I would do this asap, b/c if you don't fix it, and get in a wreck, YOU WILL NOT HAVE AN AIRBAG.
RixsFixes
Radio Code Pro
  • 2200 Answers
  • Posted on Jan 17, 2010
SOURCE: how do i change the battery in a 2005 hyundai
Please view this FixYa Tip on how to change a car battery.
Thanks for using FixYa.
Anonymous
  • 4 Answers
  • Posted on May 08, 2013
SOURCE: 2005 Hyundai Tuscon Catalytic Converter
usually under the car at the exhaust pipe
3answers
2006 Hyundai elantra air bag light sensor where is it and how to reengage passenger air bag
check fuses and relays their are different locations for air bag sensors and their is also seat belt sensors and seat switches [check the connections under the seat ]---their are sensors under the front bumper behind the valance by the radiator support also if air bag curtains passenger side between inner fender, door and door pillar the following links have information or what to look for and assist in solving your problem the recall doesn't cover your vehicle but it pertained to the passenger air bag problem as well as the 05 posting
Why is my airbag light on 2005 Hyundai Elantra Air Bags Frontal Sensor Control Module Problems More than 280 000 Hyundai Elantras Recalled Over Air Bag Problems
2helpful
Do I need any special tools to replace the timing belt on a 2005 Hyundai Tuscon v6?
u will need a 1/2" drive air impact gun and a compressor to run it to remove the crankshaft balancer.
Recall on this problem
Thanks for the information! Very useful.
10helpful
99 hyundai sonata airbag light and reset.
There are no campaigns/recalls for the SRS (Supplemental Restraint System - Air Bag). However, there is a Service Bulleting regarding the wiring harness under the seats:
DESCRIPTION: Motion of the side impact air bag wiring harness and connector may result in illumination of the air bag warning light and one or both diagnostic codes listed below:
  • B1378: Driver side air bag (DSAB) resistance high.
  • B1382: Passenger side air bag (PSAB) resistance high.
This campaign provides a new side impact air bag wiring harness connector mounting procedure. VEHICLES AFFECTED:
  • Model : 1999 - 2002 SONATA vehicles
  • Production date range: - Produced through July 23, 2001
  • VIN range: - Produced through KMHWF35H82A526636
SPECIAL NOTES: The service procedure to be followed depends on the original wire harness routing under the seats. The required parts are different for each procedure.
  • For vehicles produced on or before June 30, 1999, use the procedure for Type 1 seats. Order service kit part number 88010-38A00.
  • For vehicles produced on or after July 1, 1999, use the procedure for Type 2 seats. Order service kit part number 88010-38B00.
If your vehicle doesn't fall within the production range, it's not affected.
I recommend you take the vehicle into a Hyundai Service Department and ask them if your vehicle has had this repair already. If it doesn't apply, pay the diagnostic fee to find out what the problem is. They will give you an estimate of repairs (parts, labor, tax, time-frame, etc.).. Then you'll know what the problem is.
5helpful
Airbag light is on - 2003 Tiburon
section_closed.gif 2003 HYUNDAI TIBURON Recall ID from NHTSA: 02V290000 Auto Recall Date: NOV 05, 2002 Vehicle Component: SEAT BELTS:FRONT:BUCKLE ASSEMBLY Model Affected TIBURON Estimated Vehicles Affected: 7382 Recall Details Auto Recall Date: NOV 05, 2002
Vehicle Component: SEAT BELTS:FRONT:BUCKLE ASSEMBLY Estimated Vehicles Affected: 7382 Model Affected2003 HYUNDAI TIBURON
2003 Hyundai Tiburon Defect Summary:ON CERTAIN PASSENGER VEHICLES, THE DRIVER SEAT BELT BUCKLE WIRING COULD BE DAMAGED BY INTERFERENCE WITH THE DRIVER SEAT CUSHION HEIGHT ADJUSTER MECHANISM.
Defect Consequence:DAMAGED DRIVER SEAT BELT BUCKLE WIRING COULD CAUSE THE SEAT BELT WARNING LAMP OR THE SUPPLEMENTAL RESTRAINT SYSTEM (SRS) AIR BAG WIRING LAMP TO ILLUMINATE. IT COULD ALSO CAUSE THE AIR BAG FUSE (CAVITY NUMBER 5) TO OPEN, PREVENTING AIR BAG DEPLOYMENT. NONDEPLOYMENT OF AN SRS AIR BAG IN A CRASH WHERE AIR BAG DEPLOYMENT IS WARRANTED COULD INCREASE THE RISK OR SEVERITY OF INJURY IN A CRASH.
Remedy:DEALERS WILL INSTALL A NEW DRIVER SEAT BELT BUCKLE, IF NECESSARY, AND WILL PLACE A PROTECTIVE COVER OVER THE DRIVER SEAT BELT BUCKLE WIRING TO PREVENT DAMAGE FROM OCCURRING. OWNER NOTIFICATION BEGAN ON MARCH 24, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HYUNDAI AT 1-800-633-5151.
Notes: HYUNDAI MOTOR COMPANY 056
2helpful
2answers
its part of your exhaust and cannot be replaced yourself. take it to a local shop and not the dealer and it will be a whole lot cheaper
2helpful
2answers
Chronic problem with airbag light staying on.
Not sure of the year of your car, but there was a recall to resecure the harness connector. If it is 2005 the entire airbag harness should be replaced, Sorry only the dealer can access the air bag info.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
