I am waiting delivery of replacement grill element. and don't see need for fan. electrician can isolate fan when installing new grill would that be ok?
NO NEVER EVER DISCONNECT FANS OR ANYTHING ELSE ON YOUR COOKER.
Your cooker may have at least two fans, one for heating the oven cavity and one for cooling the electrics etc inside the oven. If the fan is noisy, check to see the fan has not come loose on the motor (maybe left had thread) if the fan is ok, then the fan motor may need replacing!
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
hope u find this useful. thank you.
SOURCE: replace the grill element in electrolux EOB847 fan oven
Yes, you do have to access from the back side.
SOURCE: replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
SOURCE: neff b1421n not heating up, grill and fan ok
breakers off ,,,back wall bottom center is a mounting plate 2 screws to take out the pull out wires and remove wires(careful not to let them slide back in)install new element...wires first the push back in place(no need to open back) don't forget breakers on now...you did it.... good for you.
SOURCE: Large oven doesn't heat up. Heating element gone??
Hi, In a word yes. As for who you can contact, I'd suggest only an authorized b/s/h (bosch/thermador/gaggenau) service provider. I used to be one for over 10yrs. but now work exclusively for sears...I'm not sure if I made a good choice or not yet, lol ! I digress. It is quite possibly not even the element as the gaggenau have cut-outs (they are actual thermal fuses that cannot be reset, they must be replaced) built into the bake circuit that can open often times. This of course unless you're certain the bake element is defective. Check your local directory under appliance service or a vendor who sells that line may be well equiped to direct you for quality service in someone they trust and are proficient. Hope that helps, good luck. macmarkus :)
