Question about Siemens optiPoint 500 Standard Corded Phone
Change internal directory on optipoint 500
Change display name of extension
    New Friend:
  • 3 Answers
The extension name and extension number are set in the system programming. Use manager 'e' and change them in the station view. If you are swapping people around and want them to keep their extension numbers and names, you should re-patch the cables feeding to the wall sockets rather than change the programming (if you can).
Posted on Nov 26, 2014
2 Suggested Answers
Anonymous
  • 62 Answers
SOURCE: Features keys
To add an Extension Key, enter [*91] and choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
Posted on Nov 17, 2009
Anonymous
  • 62 Answers
SOURCE: programmed speed dial - internal calls
To add an Extension Key: -
DONT lift handpiece, enter [*91] then press a vacant memory key and then choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
To dial an Extension Key: -
Lift handpiece.
Press the memory key you programmed.
Storing a personal speed dial number: -
Lift handpiece.
Dial [*92]
Dial memory number.
(*0 - *9 for personal numbers)
Press the [ü] key.
Dial 0 then the number to be stored.
Press the [ü] key.
Hang up.
How to dial speed dial numbers: -
Lift handpiece.
Dial [*7]
Dial memory number.
(001-999 for system numbers)
For Example: [*7*0 ü] will call the personal number stored under position *0.
[*7001 ü] will call the system speed dial number stored under position 001.
Our school has a Siemens 500 OptiPoint 500 advance phone that has a greeting one. Can't find out in any of the manuals as to how I can go about changing it. Can anyone out there help me?
We always programme the voicemail to 555. If you have something different change what is below, which is our 'one sheet' user guide from www.dschiltern.co.uk
All Types of Phones
1. Your mailbox number will be the same as your extension number.
2. Default password is 1 2 3 4
3. Voicemail group number is 555 (unless programmed differently)
Before callers can leave voicemail messages you must activate your mailbox and record your greeting message. We would suggest something along the lines of
"You are through to the voicemail of . . . . I am sorry I am unable to take your call at the moment but please leave a message after the tone and I shall get back to you "
To Record Your Greeting Message
1. Dial the voicemail group number (usually 555)
2. Enter your password (default is 1234)
3. Keep pressing 3 to scroll to greeting messages
4. Press 8 to toggle between your two greeting messages
5. Press 0 to change the message and follow the instructions.
To leave voicemail just press 'Release' or hang up.
Responding to Voicemail
On a display phone you will see "You have messages" on the top line and "Display messages?" on the bottom line. Press tick twice to go to voicemail and then enter your password.
On Siemens 'Entry' phone or display phones with a 'voicemail' button, just press this button and enter password when asked.
On ordinary analogue phones you will get broken dial tone. Dial the voicemail group number (usually 555) and enter password.
In all cases you will then be able to listen to your messages.
To delete a message press 0. It will ask you to confirm by pressing 0 again.
Sep 17, 2014 | Siemens optiPoint 500 Advance - Corded...
Programmed speed dial - internal calls
Lift handpiece.
Lift handpiece.
Dial [*92]
Dial memory number.
Press the [ü] key.
Press the [ü] key.
Hang up.
Lift handpiece.
Dial [*7]
Dial memory number.
Jan 19, 2009 | Siemens optiPoint 500 Standard Corded...
Can Siemens optiPoint 500 phone be used at home
An "Optipoint 500" phone can not be used at home!
It is a digital phone, specifically designed for Siemens digital phone systems. Do not plug it in at home. That could damage the phone or may knock your phone line off.
However you can use a "Optipoint 500 IP" phone at home for voice over IP calls. But this would be connected into your broadband router and would connect via the web to your companys Siemens phone system.
Nov 25, 2008 | Siemens optiPoint 500 Standard Corded...
Cant seem to find how i change the display name on my Opti500
Usually changed by your Siemens system programmer.
Can be changed by the customer using Manager C software or by using an optiset E Memory Handset.
Nov 12, 2008 | Siemens optiPoint 500 Standard Corded...
Revising extension directory on LCD
Correct. Changes are done in system programming. In a TDA it resides in system program 004. You get there by going to the main phone or phone used to program, dial PROG **1234 004 and enter the extension number of the name you want to change. It will display the present name and let you use the keypad to spell out new names. For example 2 gives you ABCabc2. The right arrow steps to the next character and ENTER saves it.
Carl
Sep 23, 2008 | Panasonic KX-T7633 Corded Phone
Features keys
Sep 17, 2008 | Siemens optiPoint 500 Standard Corded...
Changing the time on a siemens optipoint 500
here you go , follow this on your main phone to reset your time.
press sevice button ( top left )
press *95
press *95 again and press tick
press tick again
press right arrow key until you come to time
press tick key . then press *
enter time (hhmm) then tick key
press main service button and your done.
Jul 12, 2007 | Siemens optiPoint 300 basic...
Siemens optiPoint 500 Standard Corded Phone Logo
1,250 people viewed this question
Top Siemens Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
