I have this machine and I need a manual with instructions on how to thread the machine and bobbin.
manuals for kenmore on internet go to search box type " Kenmore sewing machine manual"or you can shown actual threading,dial tension adjustment etc.,...on www.youtube.com
on search box type "Kenmore sewing machine repair" happy sewing,regards
Go here - Kenmore Sewing Machine Manual
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning
with the spool, guide the thread through the thread guides to the
tension assembly. Pull the thread through the tension assembly and test
it to make sure the tension is working correctly.
(To do this
test,adjust your tension setting to normal or medium or 5 or something
in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the
thread. It should pull noticeably harder.) If it passes this test,
continue up through the take up lever,then down through the thread
guides to the needle. Make sure your needle is fully inserted and
turned the correct way.( If you load your bobbin case from the left
side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are
some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
SOURCE: Threading the Bobbin
Place the bobbin in the bobbin case making sure the thread feeds clockwise. Draw the thread through the slot on the case. Continue to draw under the tension spring and through the opening pulling out about 6" of thread. Hold the latch open, position the bobbin case into the suttle and release the latch. THe case should lock into place when the latch is relaeased.
With the top thread, hold out about 5" to the left. While holding on tot he top thread, turn the hand wheel toward you and you should see a loop at the feed dogs. grab the two thread and bring them behind the presser foot.
Bonnie
SOURCE: Bernina Bernette 65 sewing machine
I had the same problem. I'm a novice sewer. I just bought my machine. It did the samething, tension didn't work, the thread kept knotting up underneath, and the fabric kept curling up in the back.
I adjusted the tension knobs to no avail. Then it kept bothering me that it was curling up. I then decided to set the dials back to where the factory had them and adjusted the presser foot just a hair counterclockwise and I haven't had anymore problems.
The other day the needle almost broke because the tension was tight on the thread. You have to make sure that the needle is at it's highest point to get it to release the fabric so you have a thread tail.
This is my first purchased machine. I had a New Home years ago that was given to me, however it blew away in the tornado of 1991 in Kansas and I never replaced it. I really do love this machine. I don't believe I will ever want another.
