Question about Kodak EasyShare Office Equipment & Supplies
I can't install a new ink cartridge into my easyshare printer as the piece that comes down when printing a picture is stuck in the down position I have tried holding the transfer button at the
I can't install a new ink cartridge into my easyshare printer as the piece that comes down when printing a picture is stuck in the down position I have tried holding the transfer button at the same time as the left arrow but it hasn't done anything to release it
2 Related Answers
Anonymous
SOURCE: Kodak Easyshare G600 printer dock problem!
I HAD THE SAME PROBLEM. tALKED WITH THE KODAK TECH LINE AND THEY TOLD ME TO...TURN OFF PRINTER, HOLD TRANSFER BUTTON AND LEFT ARROW DOWN AT THE SAME TIME AND TURN THE PRINTER ON. DO THIS THREE TIMES. iT WORKED FOR ME. GIVE IT A TRY.
Posted on Nov 27, 2008
mariolands
mariolands
  • 2296 Answers
SOURCE: I installed a new ink cartridge in my Primera
Have a look in the User Manual for this model: http://www.primera.com/pdfnew/510984_link.pdf
Also, have a look here for Troubleshooting with this printer http://www.primera.com/knowledgebase.html
Posted on Nov 19, 2010
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
Will not print. e 2 flashes on screen
ERROR CODE CANNON MP150/MP160
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E16 - Ink remaining is unknown
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
You can gave it a good clean out try.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 13, 2010 | Canon PIXMA MP150 All-In-One InkJet...
We cannot get out printer to print. easyshare
we replaced printhead and it wants us to calibrate and replace ink color ink cartridge, and before we put the printhead in , it had 1/2 full color in cartridge
Jan 10, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 24, 2009 | HP PSC 750 All-In-One InkJet Printer
Light in color and won't copy dark. It come out light purple
you may try
1) color ink cartridge--- no enough ink or the cartridge ink channel dryer and constipated, refill ink and put down the cartridge bottom surface to water a little for 1 hr, then set back. or change a new cartridge if not fixed go next
2) print head--- the ink channel dryer and constipated, take out print head clean it's ink channel using cleaner or steep in water (do not touch circuit pin area with water) 20 minutes or longer. then set back and test (you can do more times), still not fixed, your print head have to change.
Feb 06, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Images print to light to see
Please follow the steps to clean the print head and install it try to print
Jan 30, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Epson stylus photo 1290 'bk ink cartridge not installed properly'
Ameter:
Remove the black ink cartridge.
Check the place where the new cartridge should go. Check for a round small piece like a bushing or a little piece of pipe, stuck at the ink entrance of the printing head. This is a piece from the old cartridge, that sometimes gets loose and remains in place,and when the new one is placed, it doesnot go down to the right place to make contact with the electric connectors in the printing head.
If nothing solves...reinstall the printer drivers.
Good luck and Merry Christmas
Emiliosan
Dec 09, 2008 | Epson Stylus Photo 1290 InkJet Printer
Not printing
Contact Kodak! I had similar problem after a paper jam. I phoned three days ago and this morning, a new printhead arrived along with two new cartridges. Have installed the printhead and printer is printing beautifully! Thank you Kodak! Great customer service!
Aug 25, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Jul 31, 2008 | Kodak Easyshare Printer G600 Thermo...
35 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
